Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 11-05-2011, 01:17 PM   #1
dormers with no flashing
I have an 80 year old brick cape cod. The roof was replaced several years ago--but the roofer did not put flashing around the dormers!!! What can be done to keep the water out?? can flashing be placed on top of the shingles?? Is there a putty that can be used for a temporary fix until spring?? help please!!!
weezie903 is offline   Reply With Quote
Old 11-05-2011, 01:32 PM   #2
"Nail-Bender"
Are you sure that they didn't re-use the old flashing?
(Not what we would do - better than nothing!)
Up the sides of the dormer - the flashing probably will be under the shingles -
you wouldn't see it.
On the front of the dormer - should be exposed - over the shingles.
How do you know there's no flashing - leaks?
Pictures help!?
rossfingal
rossfingal is offline   Reply With Quote
Repair or Replace Roof-to-Wall flashing Learn as i go Roofing 6 03-10-2011 04:19 PM
Flashing repair Squash_Pro Roofing 9 05-07-2010 01:50 PM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 11:08 PM
Chimney Flashing mfitzsimons Roofing 4 04-20-2009 11:00 PM
Flashing around Dormers? dbogey Roofing 6 04-23-2008 12:32 PM
