Dormer Flashing? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-10-2011, 04:34 PM   #1
Dormer flashing?
Just had new roof put on today and the roofers put the shingles over the flashing on the dormers. They ran a buck bead of caulk over where the shingles meet the dormer. I can see the calk braking up and water going under the shingles. What do you guys think?
Thanks,
Guy
photo guy_43420 is offline   Reply With Quote
Old 11-10-2011, 06:09 PM   #2
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
You needed roofers on the roof, not those 'other people' for want of a better description. A roofer should be able to tear it off/up and correct your problem.
tinner666 is offline   Reply With Quote
Old 11-10-2011, 06:28 PM   #3
This is what it looks like.
Old 11-10-2011, 06:36 PM   #4
Pro Slate Roofer
tinner666's Avatar
Yeah, the flashing on the sides comes down and crosses over that flashing which is supposed to be on top of the shingles. That's why it's called 'Termination Flashing' in all the roofing manuals.
Now, water is also being trapped at the corners since the layers have been reversed, as stated in my first sentence above.
Old 11-11-2011, 01:48 AM   #5
Residential Designer
AndyGump's Avatar
Rewards Points: 684
Send a message via Skype™ to AndyGump
Not to put too fine a point on it but your "roofers" suck.
Andy.
AndyGump is offline   Reply With Quote
Old 11-11-2011, 06:10 AM   #6
That is what I'm afraid of, such a bummer these guys came highly recommend.
Old 11-11-2011, 06:22 AM   #7
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Before you get too critical, check to see if the termination flashing is under that last course of shingles . Those may be a decorative finish course they install over the termination flashing......
....if not .....they suck.....
tcleve4911 is offline   Reply With Quote
Old 11-11-2011, 06:24 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,608
+1
Still not a fan of that application but that could also be the case.
Old 11-11-2011, 06:26 AM   #9
Pro Slate Roofer
tinner666's Avatar
It's under there and they suck, as you put it. It completely negates the layered approach necessary at the corners. Now that the flashing is also full of holes, it should be replaced. It's supposed to be on top for a purpose and the exposed flashing is decorative.
Old 11-11-2011, 06:33 AM   #10
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Some roofers just install rolled flashing they buy at the store.
They don't have a break or order pre-bent.
They bend it with a 2x4 or bang it against the building until it kind of fits, ending up with a wavy, ugly, but functional detail.
The decorative course of shingles hides that.
....not all are as detail oriented as you are, Tinner......
Old 11-11-2011, 06:41 AM   #11
Thats what worries me is that there is a bead of calk from where the shingles meet the dormer. They have nails in and calk over that. I can see that braking down and leaks.
Guy
Old 11-11-2011, 07:53 AM   #12
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
I know it looks like there's potential for leaks but it's standard practice in the industry....seen it many times....
The last line of defense is Ice & Water shield installed as an underlayment.
Not just at the eaves but all the way up to the sidewall and even up 8-10".
Did they do that?
Old 11-11-2011, 09:27 AM   #13
I called them they are comming back and fix it up better. I will ask them about the ice guard they comee back.
Thanks,
Guy
Old 11-11-2011, 11:17 AM   #14
Pro Slate Roofer
tinner666's Avatar
I'm going to break my main rule and comment again.
For argument's sake, of course. And for informational value.
If there's supposed to be a decorative course, why did they stop one course early? That's the nail line and a few inches of the back of the shingle showing. To add another course would then mean another handfull of nail holes in what used to be good flashing.
Not that I've ever passed one done that way when I inspect roofs for the banks/mortgage people.
The Following User Says Thank You to tinner666 For This Useful Post:
rossfingal (11-12-2011)
Old 11-14-2011, 06:49 AM   #15
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
It's all in the details, huh?
I never nail the decorative course for that very reason.
I glue them down with Lexel
Dormer flashing and roof trim Joe1. Roofing/Siding 10 08-17-2010 11:48 AM
Step flashing on front dormer Windows Roofing/Siding 8 07-23-2010 07:11 AM
Vinyl siding corner posts and flashing on dormers rhastler Building & Construction 7 06-05-2009 10:08 PM
Dormer Flashing yorkie General DIY Discussions 2 05-16-2008 06:18 AM
Dormer Flashing yorkie Roofing/Siding 3 05-15-2008 04:03 PM
