Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 01-02-2013, 09:10 PM   #1
Door awning structural help
I want to install a awning over our basement door and am trying to figure out how deep the over hang can be before either brackets are needed and then how deep before posts are needed. The existing roof is 5/12 so will follow and probably use 2x6.
Thanks,
cww1 is offline   Reply With Quote
Old 01-02-2013, 09:47 PM   #2
Any more then 2' I would not trust it with out some form of support.
Post, wall brackets, something.
What can happen depending on what your mounting it to is it will sag or pull away from the wall causing it to leak.
Old 01-03-2013, 08:33 AM   #3
I have seen engineered roof trusses overhang 4 feet without supports. But if you're building them on your own, I wouldn't span more than 2 feet.
bcdemon is offline   Reply With Quote
Old 01-04-2013, 12:32 PM   #4
Roofmaster
Can you give more info?
Ranch?
Colonial?
Wall Height?
Picture?
" A lot of men build things, and a lot of things fall down "
Old 01-04-2013, 05:51 PM   #5
No good pic of the whole wall, I can get one this week end. The doors are unfortunately below grade by 22" and the whole well is 81"x38". Siding is going to be replaced as is door and the door well. When the door well is replaced we are putting in a dry well for what water makes it in but want the awning to control as much as possible. The grade around will be changed as well.
Old 01-04-2013, 06:11 PM   #6
Going to be interesting trying to put a roof over that with T111 siding.
No good way to keep water from rotting out the siding without some major rework.
T11 can not be any closer then about 6" from any solid surface such as a roof without splash back which will cause it to rot.
Old 01-04-2013, 06:25 PM   #7
Ah sorry, the siding and sheathing are being replaced and vinyl is going up. The height is one of my concerns as the awning would have to be higher than the band board due to the step up or stop with enough clearance for head room on the step.
Old 01-05-2013, 11:50 AM   #8
Roofmaster
Looks like a no brainer to me. Put a shed roof over it with two posts outboard to support the roof. screw a 2 x to the T1-11 level, saw cut and remove. Flash under and over the new shingle roof. Screw a 2 x 8 ridge plate to the studs of the house with 2- 3/8 x 3.5 inch Lag screws per stud, and frame her out with 2x6 rafters. Put vents on the sides. I would make it bigger than the well by at least a foot for wind blown rain, and with the posts you could even install trellis for some privacy, and partial wind block.
Good Building.
The Following 2 Users Say Thank You to jagans For This Useful Post:
joecaption (01-05-2013), Windows on Wash (01-06-2013)
Brick veneer or Structural Brick? nimblemotors Building & Construction 19 02-22-2013 09:11 PM
Best way to repair rotted structural wood member? miamicuse Carpentry 20 11-19-2011 05:30 PM
Opening up a load-bearing wall. Do I need a structural engineer? Ironlight Building & Construction 3 04-18-2011 12:03 PM
Unstable Structural Wall joe_cole5000 Building & Construction 8 02-01-2010 09:33 AM
Concrete steps and stucco cracked-Is this structural problem? yummy mummy Building & Construction 17 04-14-2008 10:24 AM
