Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-06-2010, 08:22 PM   #1
AAK
Question
Dome skylight leaking
Hi,
I have a leaking dome skylight that sits on top of a flat roof. The skylight has a diameter of about 6' feet. The leak seems to be coming from the location where the skylight sits on the roof. The area between the skylight and roof looks like it had been sealed with a black henry roofing cement which is now cracked -probably where the water enters and drips through below ceiling.
I know I will need to remove all the old cracked roofing cement and clean the area thoroughly before applying a new layer.
What is the best material to use for sealing the area between the skylight and the roofing material? and what is best to use on the glass of the skylight?
I know the black roofing cement cracks easily, so is there any other type of longer lasting material or solution for this leak?
Thank you and I appreciate all help and response for this matter.
-Aaron
AAK is offline   Reply With Quote
Old 10-08-2010, 06:47 PM   #2
Shut in w/o Home
seeyou's Avatar
Try this (found at most roofing supply stores):
http://tiny.cc/l8hw0
seeyou is offline   Reply With Quote
Tags
dome skylight, leak in roof, roofing repair, skylight
leaking skylight? cbzdel Roofing 2 06-03-2010 07:09 PM
HELP - Broken Roof Hatch Dome Skylight alanarthur Roofing 7 02-11-2008 07:57 PM
Leaking fixed skylight mt232 Building & Construction 5 11-23-2007 11:12 PM
Skylight leaking advice needed!Thanks Beeper29x Roofing 12 10-04-2005 09:53 PM
