Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 08-17-2009, 01:51 PM   #1
Dome Roof: Need help flashing Skylights?
If we have 5 skylights set in a pentagram on a dome-roof, what's the best way to flash in-between them? Moneteray Dome circa 1985. We're re-doing the skylights now. Last roofer used an ice-dam water-shield rubber material with a rough protective texture on top over the flashing between the windows, and regular flashing around the edges and sealed that.
Not sure that was sufficient.
dunion is offline   Reply With Quote
Old 08-17-2009, 03:38 PM   #2
Pro Slate Roofer
tinner666's Avatar
The flashing needs to be made for each lite so each overlaps correctly. No way I could explain in full detail. These have no ice and storm shield, and only place needing caulk was a little dab at the top corners, of the top 2 lites.
http://rcs.si-sv2628.com/show_album_...8&file=764&s=0
Frank
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Chinagirl (12-18-2011)
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
