Doll House Shingles - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-16-2010, 11:34 AM   #1
Doll house shingles
Can you give me an idea on how to put on doll house shingles on the type of doll huse that the attict roof opens to see the inside.
also any good ideas on cutting wood shingles to fit. I have completed the fron of the house with no problems but forsee several problems on the back that has hinges for the roof to open.
Thanks DLM
dlm1 is offline   Reply With Quote
Old 05-16-2010, 12:06 PM   #2
Commercial Roofing
AaronB's Avatar
I have been waiting for this topic for years... Never had a chance to use it...
I helped a friend of mine do a wood shingle roof on his daughter's doll house. We hot glued the shingles on and cut them with Xacto knives. We even went so far as to use the old school technique of shaving the hip shingles in opposite directions to make them water tight.
As far as the opening, I think I would KISS it and roof it while closed and leave about 1/16" between the shingles on and around the opening.
Thanks for letting me share my heterosexual male bonding experience. LOL
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
The Following User Says Thank You to AaronB For This Useful Post:
Leah Frances (05-16-2010)
Old 05-16-2010, 12:49 PM   #3
Doing This Way Too Long
Rewards Points: 532
BTW, if you are cutting the shingles yourself and have a good drill press, break the handle off an old chisel and chuck it up in the press and use it as a splitter. Clean blocks of 1X OR 2X cedar or pine cross cut to length work nicely.
....and, obviously, UNPLUG THE DRILL PRESS!!
OldNBroken is offline   Reply With Quote
replumbing an old house simonfrog Plumbing 7 01-30-2012 05:45 AM
HVAC for c. 1956 House. What would YOU do? David911 HVAC 10 02-08-2010 06:58 PM
Attic Fan AND Whole House Fan PapaGnome HVAC 6 02-15-2009 03:28 PM
Hello. I moved my house... shtoink Introductions 10 06-25-2008 02:40 PM
Re-siding house jdig Building & Construction 5 04-10-2007 10:15 AM
