Does Timing Of Roof Matter? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-21-2013, 12:24 PM   #1
Does timing of roof matter?
is there a difference in price and quality for when a roof is put on in late spring, summer or early fall?
in other words, are roofers burnt out by end of summer/fall? and do prices go up or down by end of summer/fall?
Thanks gents!
eugierom is offline   Reply With Quote
Old 03-21-2013, 12:43 PM   #2
Roofmaster
Rewards Points: 2,210
Spring is best, all the way around.
Old 03-21-2013, 12:55 PM   #3
Love for Construction
<*(((><'s Avatar
I would second for late spring, so the summer heat rolls around and softens the roof causing it to stick together better before winds reap havoc. I'm no roof expert, but this has always been my thought on the subject.
-luke-
<*(((>< is offline   Reply With Quote
Old 03-21-2013, 03:38 PM   #4
Rewards Points: 656
Spring or fall.
Nothing wrong with hot summer days either, roof may just take a little longer because conscience and sane roofers get off the roof when its 100+ outside.
Spring is likely best for pricing as well, as shingles tend to cost more in the future then they do now.
PatChap is offline   Reply With Quote
Old 03-21-2013, 06:07 PM   #5
747
registered
747's Avatar
Rewards Points: 534
Beginning of spring. Your first on there list.
747 is offline   Reply With Quote
Old 03-21-2013, 07:16 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 2,140
Summer? The roofers start earlier in the day.
Timing? Best time is when the roofers are hungry.....where you are determines that. Most people don't put on a roof until it leaks....and most roofs don't leak until it rains. Rain stops, no leak....don't need a roof.....
Get estimates....get references.....but the guy that says he can start today? You might want to avoid him....he is too hungry...unless he just happens to have a slot to fit you in.
Old 03-23-2013, 10:46 AM   #7
roofingquotes's Avatar
Spring is the best time for roofing. Summer is good too, but you don't want your contractor to get burnt in the sun. Just make sure there not working during peak hours when the sun can be very hot. I wouldn't recommend it in fall because it can be very windy during those months.
roofingquotes is offline   Reply With Quote
Old 03-23-2013, 11:43 AM   #8
Rewards Points: 626
Mid spring to middle summer is a good time but spring time is the best for pricing roofers have had most of the winter off hungry for money and have a over stock of roofing materials. So you may get a good price. But all ways ask around and get quotes and talk to people who had work done by them is always your best way to go. also spring is really a great time to roof the roof gets to get all nice and hot during the summer to really seal it good. as aposed to fall were the shingles don't warm up enough to get the tar to stick to each other as well then a good fall wind storm and whamo shingles go flying. and if your worried about that happening make sure they 6 nail the shingles down.
Nailbags is offline   Reply With Quote
Old 03-23-2013, 01:05 PM   #9
Rewards Points: 194
I'm getting my roof done late spring. There is still snow on it right now.
Larryh86GT is offline   Reply With Quote
help! strange horizontal bubbles on new roof dfwnewroof Roofing/Siding 49 11-17-2012 06:46 AM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 03:17 PM
Flat roof and insulation quandry paredown Roofing/Siding 2 08-20-2010 11:50 PM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
