Does This Roof To Wall Flashing Look Right? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 12-30-2008, 09:38 PM   #1
Does this roof to wall flashing look right?
I recently had my roof replaced and I am concerned about the flashing job done. The lower (horizontal) edge of the flashing was placed on top of the architectual shingles, nailed in about every 8" (through the new singles) and then covered with dab of roofing tar. The existing metal flashing was re-used (if was not done correctly in the first place - was not fastened in any manner). Aside from the sloppy caulking and cracking my vinyl siding in one place, did my roofer do me wrong? Thanks for the help.
Does this roof to wall flashing look right?-img_0144.jpg   Does this roof to wall flashing look right?-img_0142.jpg   Does this roof to wall flashing look right?-img_0136.jpg
jiminvabeach is offline   Reply With Quote
Old 12-31-2008, 02:18 AM   #2
Tom Struble's Avatar
Rewards Points: 2,002
is it leaking?
Tom Struble is offline   Reply With Quote
Old 12-31-2008, 02:25 AM   #3
Wethead's Avatar
Looks good, I would just ad more silicon
Need Help With Your Pump?►WeT HeaD Pump Repair ► Watch Me On YouTube: Pump Repair TV
Wethead is offline   Reply With Quote
Old 12-31-2008, 06:18 AM   #4
the roofing god's Avatar
Send a message via MSN to the roofing god
YOU COULD HAVE PAID TO HAVE THE BOTTOM COURSES OF SIDING removed,new flashing installed(nailed to wall),and had it reinstalled.
If you didn`t pay for that "extra work",then you got what you paid for
"If it`s worth doing,It`s worth doing right!!"
www.ADVANCEDROOFINGNEWYORK.com
the roofing god is offline   Reply With Quote
Old 12-31-2008, 07:49 AM   #5
Thanks for the replies
Thanks for the opinions. Don't know if it leaks, as we have not had a hard rain in that direction since it has been installed.
Regarding whether I got what I paid for, I pointed the flashing out during the estimate and my roofer said he would fix it, make it right. Sounds like I should have gone into more detail with him.
I recall reading somewhere that in coastal regions, the flashing should be installed under the shingles to keep the wind from damaging the flashing.
For the way it IS installed, should the leading edge of the flashing been sealed to the roof with tar instead of or in addition to nailing?
I know that the nails were covered with tar, but isn't it preferred not to nail through the top of a shingle?
Thanks again for all the help.
Old 12-31-2008, 07:57 AM   #6
FOR THE SITUATION INVOLVED,NAILS THRU FLASHING,AND SEALED WITH COLOR COORDINATED GEOCELL SEALANT WOULD`VE LOOKED BETTER,you should have gone into more detail-what you have works,and the flashing should be over the shingles so water runs off the flashing onto shingles below
Old 01-06-2009, 12:23 AM   #7
i think the best way to secure the shingle leg it to install a tab and fold it over instead of nailing thru it
Old 01-06-2009, 07:31 AM   #8
could you be more descriptive about what you mean ?
What is a shingle leg ????-never heard that before
Old 01-07-2009, 10:03 AM   #9
Commercial Roofing
AaronB's Avatar
There are many details that would have worked here.
I have seen this method used many times with no problems. Like the roofing God said... if you wanted a better detail, then you probably could have gotten one but would have added some extra cost.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 01-07-2009, 10:20 AM   #10
i meant the leg of the flashing that laps over the shingles sorry for the confusion
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 11:00 PM
leaking tar and gravel roof meleis Roofing/Siding 9 01-05-2008 11:27 PM
Ventilating Roof with no ridge? NateHanson Roofing/Siding 7 12-30-2007 05:33 AM
Flat roof addition - Joists connected to structure via legerboard?? Rhino17 Building & Construction 2 09-01-2007 07:56 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
