Does Ridge Venting Make Sense If I Do Not Have Eaves/soffits? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-17-2008, 11:11 PM   #1
Does ridge venting make sense if I do not have eaves/soffits?
Any advise would be appreciated.
nymark is offline   Reply With Quote
Old 06-17-2008, 11:17 PM   #2
On a gable style home, it will help through thermal bouyancy only and not get the full effect, but it will be significantly better than standard static air mushroom vents, pot vents, turtle vents, or whatever you call them where you are from.
Ed
Ed the Roofer is offline   Reply With Quote
Old 06-17-2008, 11:26 PM   #3
Thanks. When you say gable do you mean simple. My house is basicallly a rectagular With a side vent and a roof vent witj an automatic fan. But the roof ends where the wall ends (no soffits).
Old 06-18-2008, 12:20 AM   #4
Yes, a gable style home has the ridge board length the same length as what the eaves are.
Get rid of the fan if you do use the Ridge Vents.
Ed
Old 06-18-2008, 12:39 AM   #5
I should have been more clear and explained more. I do not have eaves. So there are no intake vents which would create the circular air flow from the eaves to the ridge. I received a bunch of quotes - the cheapest quote was from the only person who did not include the ridge vent because he said it was a waste without the eaves and I should stick with the roof fans vents (with thermostats) and one on the side of the house (it's only 1,200 sf). Is he right?
Old 06-18-2008, 12:50 AM   #6
Oh, you made yourself pefectly clear regarding not having any eaves for soffit ventilation.
But, you did not mention that you were getting a new roof done.
That changes things dramatically.
You DO have a great and very viable option to provide lower roof intake ventilation.
There is a great product that I have been using for the past 6-7 years, called Smart Vent, by DCI Products Inc.
It is a shingle over style intake vent that gets installed on top of the plywood decking witrh a 1" wide slot cut out. It is a tapered product, which winds up being only 7/8" high at the actual eave edge and gets as thin as about 1/16" 12 inches higher on the roof.
Myself and many other roofers who care greatly about making sure that the roofs will last their warranty period of time, always refer this product.
Here is a link to the Smart Vent page with some illustrations as to how it gets installed. Almost every shingle supply house either carries it in stock, or can quickly order it fro them and in the rare circumstance that their are no local suppliers, you can contact them directly.
http://www.dciproducts.com/html/smartvent_eave.htm
Ask for either Jack or Steve Henderson and tell them that Ed The Roofer told you to contact them if you need to. Who knows, maybe I will get some brownie points?
Now, even without a soffit overhang, you have a remarkable and viable solution to provide the proper amount of exact balance between the ridge vent exhaust and the fresh air intake.
Ed
P.S. I have a post on this forum that shows photos of it getting installed on several jobs. Do an Advanced Search under the Username; Ed The Roofer" and the search phrase; "Smart Vent".
Old 06-18-2008, 12:58 AM   #7
Here are some of the threads that some photos are located in.
Smart Vent Photos showing Balanced Roof Ventilation from Intake to Exhaust.
Ed
http://www.diychatroom.com/showthrea...tos#post126471
and another one
You will have to follow another link to the ContractorTalk Forum where I originally posted them in these next links.
http://www.diychatroom.com/showthrea...tos#post119915
This might lead you to duplicates that arew in the last one
http://www.diychatroom.com/showthrea...tos#post119912
and here too
http://www.diychatroom.com/showthrea...tos#post116573
Ed
Old 06-18-2008, 01:03 AM   #8
Awesome - thanks so much.
Old 06-18-2008, 01:06 AM   #9
I just realized that I forgot to put that link in the previous thread to the Smart Vent manufacturer.
Here it is again and I also edited the older post to add it in there too.
Ed
Old 06-18-2008, 05:15 PM   #10
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
One of the commonly asked questions about ventilation. Ask any manufacturer, and ridge vent should not be installed without equal or greater intake ventilation. All ventilation will work better with intake ridge vent wont work at all without it, although if you have adequate ridge vent for the size of your attic space, and you have equal intake, a ridge vent is a very very good form of ventilation. You can check www.airvent.com and www.rollvent.com for calculators and specifications.
Intake can be created a number of ways, but be careful of the products that replace gutter flashing/apron, as they are HIGHLY prone to snow backup. Also be careful of the intake vents that slide under shingles a few courses back from the gutter edge as these too allow free reign to water infiltration. When we need to create an intake we do it the hard way, but the only ways which will prevent damage from snow backup. This either means creating an overhang, or some how creating aiur flow behind the fascia. We have a number of methods, but it often falls down to budget. Most customers don't want to do it right when they find out how much it costs to do it right.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain safety! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 06-18-2008, 05:44 PM   #11
Thanks. It sounds like I am better off staying with the old vent.
Old 06-18-2008, 07:51 PM   #12
Ridge venting works much more continuously and more efficiently than any other type of roof exhaust vent.
Yes, it works even MORE efficiently when the proper intake ventilation is introduced into the system, because now the air will flow through the attic.
But, the same, to a much lesser degree can be stated about the cheapest and most inefficient static air exhaust mushroom vents. Even they too, will work more efficiently with proper intake ventilation, but definitely not as good as the continuous ridge vent.
Remember, the Intake Ventilation is the key and usually missing ingredient for the entire attic ventilation system.
Ed
Old 06-18-2008, 08:40 PM   #13
Would one big side vent work for intake on a 1,350 sf roof with a ridge vent? If I have a mushroom already should I leave it and add the ridge vent?
Old 06-18-2008, 10:21 PM   #14
I presume you are referring to a wall vent at the high point of the gable wall, right. That is called a Gable Vent if you are.
Technically per most studies and a lot of research, the usage of any other vents near the top of the roof will short-circuit the other attic ventilation systems in place.
Rely on the continuous ridge vent for the complete exhaust solution.
To make the exhaust ventilation work to its fullest capacity, you need the intake ventilation in an equal or even higher amount.
The Shingle Vent II Ridge vent provides 18 square inches of exhaust per lineal foot.
The Smart Vent Shingle Over Style Fresh Air Intake Vent provides 9 square inches per lineal foot.
Therefor, you would need both eave edge sides having the Smart Vent installed to add up to being equal the amounbt of exhaust ventilation that the ridge vent is capable of expelling.
Ed
Old 06-18-2008, 11:41 PM   #15
Great. So if I install the ridge vent and smart vent...... should I remove the mushroom and shut the gable vent?
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 12:03 PM
Venting roof with no ridge NateHanson Roofing/Siding 3 06-17-2008 06:35 PM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 04:22 PM
Does this design make sense? beer_geek HVAC 3 08-02-2007 06:33 PM
