Does This Plywood Or OSB Need To Be Replaced? Pic Included - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-21-2012, 03:22 PM   #1
Rewards Points: 320
Does this plywood or OSB need to be replaced? Pic included
Hey guys, about to repair a roof leak in my home due to a satellite installation. I was going to just replace some shingles and use asphalt roofing cement to make the repair, but I wanted to double check if you guys think that the wood needed to be replaced too. I don't know if I have OSB or plywood (never had to work with either since I'm a basic DIY guy and don't have much knowledge yet), but you can see from the photo what the damage looks like. It was just a small leak from two small holes, but my parents just told me about it (it is their house) and said it has been leaking for about a year.
What do you think? Can you tell from the photos if I need to replace the wood or is there some physical tests I should do (like feel if it is mushy, etc)?
Thanks.
amodoko is offline   Reply With Quote
Old 11-21-2012, 05:08 PM   #2
Rewards Points: 1,216
Replace it.
No Warranty Means- If it breaks in half you get to keep both halves.
COLDIRON is offline   Reply With Quote
The Following User Says Thank You to COLDIRON For This Useful Post:
amodoko (11-21-2012)
Old 11-21-2012, 06:37 PM   #3
Rewards Points: 320
Really? You can tell for sure I have to replace it?
If that is the case, can you just replace the wood from underneath? Or do I have to rip up the water barriers under the shingles too?
If the wood needs to be replaced, is it possible to salvage it and just do a proper rotting wood repair? The ones where you sand out everything and then put in epoxy?
I would feel more comfortable doing an epoxy repair rather than replacing since I don't want to have to rip up the water barriers under the shingle
Old 11-21-2012, 06:44 PM   #4
Gymschu's Avatar
Rewards Points: 466
There's really no way to replace that rotted wood from inside. Even if you could do it that way, you woulld still damage the water shield and damage some shingles. I suppose if it's not mushy you could shore that area up with some 2 x 4 braces nailed to the rafters on the underside. That's not an ideal solution but may keep someone from falling through the roof in that area if they are ever up there near that spot. At some point you really need to do it up right by replacing that rot from on top of the roof.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 11-21-2012, 07:04 PM   #5
Rewards Points: 320
Thanks for the reply, greatly appreciated. With an epoxy repair, I would just have to sand out the bad stuff, in which case it may be possible to not damage the barriers. If I were to do an epoxy repair AND install the 2x4 supports, shouldn't that be as close to permanent as an original repair? I thought that would last for decades if it didn't get wet again with an epoxy repair and 2x4 reinforcement.
Old 11-21-2012, 07:26 PM   #6
kwikfishron's Avatar
Rewards Points: 176
Your “barriers” are already damaged otherwise you likely would not have a leak. Any competent roofer could fix it all in just a couple-three hours assuming the roof is walkable.
Get epoxy out of your head...it has no use here.
kwikfishron is online now   Reply With Quote
The Following 4 Users Say Thank You to kwikfishron For This Useful Post:
amodoko (11-21-2012), Gymschu (11-21-2012), joecaption (11-21-2012), Missouri Bound (11-23-2012)
Old 11-21-2012, 07:44 PM   #7
Rewards Points: 320
Well if epoxy has no use here, I don't have to use it, that's why I was asking... to gain some information/knowledge on what is considered appropriate for a repair.
Thanks for the replies, I will try to educate myself before doing the repair.
Old 11-21-2012, 07:47 PM   #8
Rewards Points: 13,270
They knew it was leaking for a year and did nothing
Now there stuck with the only right way to fix it.
The shingles need to go, Tar paper removed, Plywood removed and replaced, new tar paper and new shingles.
Trying to do anything from the inside is just silly and a total waste of time.
Old 11-21-2012, 08:03 PM   #9
Rewards Points: 320
Yeah, my parents are really old now and aren't on top of things as much. If I lived closer to them I would try to get their repairs done quicker. They actually only knew about it around 6 months ago, but I said one year because I'm assuming it has been leaking for about a year since they take a while to notice things, and because there was drywall there before that was masking the leak until the drywall got stained, and then moldy. The drywall is obviously removed in the photo.
I'm going to fix it the right way, just need to do some more research about how to go about this/roof safety/etc.
Old 11-21-2012, 09:01 PM   #10
Solutions (handyman)
Rewards Points: 362
roof repair
Amodoko, It sounds as if you are trying to find an easy way out. Don't! A band-aid solution won't solve the problem. If the stain are also mold, then you probably are dealing with health issues on top of the leaking roof issue. You don't sound experienced enpugh to fix the problem. You do soul=nd smart enough to get the proper help you require. Do it properly and have piece of mind for you and your parents.
Mark Harvey is offline   Reply With Quote
The Following 2 Users Say Thank You to Mark Harvey For This Useful Post:
amodoko (11-22-2012), Gymschu (11-21-2012)
Old 11-21-2012, 09:14 PM   #11
JOATMON
ddawg16's Avatar
Rewards Points: 1,120
As an FYI....it's not that hard to remove a section of shingles.....I went through that when I was doing the roof on my 2-story addition...Once you get the first one above the area up...the rest are easy.
Follows Joe's advice...do it right the 1st time.
The Following User Says Thank You to ddawg16 For This Useful Post:
Old 11-22-2012, 01:07 PM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,834
Pretty straightforward fix.
Pull the shingles, felt, plywood.
Install new plywood, underlayment, and shingles.
That sheathing is beyond repair.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Old 11-22-2012, 03:55 PM   #13
Rewards Points: 320
Yeah, I am going to do it the right way. Am actually at their house right now for Thanksgiving, and I touched the plywood with a broom and it is extremely weak and brittle, definitely needs to be replaced as you guys suggested. I'm just a bit confused about one thing though, when you remove a section of your roof that is in the middle of your roof, do you have to install new underlayment all the way towards the top of the roof even in the unaffected areas to get overlap between underlayments?
To make my question clearer, I read some information about underlayment (specifically the storm shield stuff that is self-adhesive) installation and how you install it kind of like shingles where you start from the bottom of the roof and move up so the sections of underlayment are layered like shingles to get proper water run off. However, when you remove underlayment in the middle of your roof, you can't get that same overlap between the top edge of the new underlayment and the the bottom edge of the old underlayment. So do you just remove the staples/nails that hold the old, salvageable underlayemnt's bottom lip and then reattach it to the new underlayment's top edge to get proper water runoff? Or do you have to remove all the underlayment above the repair to install new underlayment in proper layers?
Old 11-22-2012, 04:24 PM   #14
JOATMON
ddawg16's Avatar
You just need to expose enough of the roof to remove the wood and to get up under the layer of underlayment above the damaged area.
Shoot high...in other words....don't try to expose just the damaged area...go at least 2-3 rows above...or more...if you start high, it's a lot easier to remove the shingles going down. Once that first row is off...it gets easy.
Old 11-22-2012, 04:51 PM   #15
maybe a good time to replace all the roof or at least the one side as usually if it's leaking the roof is already shot
mrairflow is offline   Reply With Quote
The Following User Says Thank You to mrairflow For This Useful Post:
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Repair or Tile Over Plywood "Insert" in Drywall MitchK Drywall & Plaster 7 05-12-2011 02:46 PM
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-25-2011 12:58 AM
Should I put new plywood ontop of old, or rip and replace? superfly Roofing/Siding 3 07-09-2009 11:37 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
