Does this plywood or OSB need to be replaced? Pic included
9K views 18 replies 11 participants last post by  guynextdoor
#1 · (Edited)
Hey guys, about to repair a roof leak in my home due to a satellite installation. I was going to just replace some shingles and use asphalt roofing cement to make the repair, but I wanted to double check if you guys think that the wood needed to be replaced too. I don't know if I have OSB or plywood (never had to work with either since I'm a basic DIY guy and don't have much knowledge yet), but you can see from the photo what the damage looks like. It was just a small leak from two small holes, but my parents just told me about it (it is their house) and said it has been leaking for about a year.
What do you think? Can you tell from the photos if I need to replace the wood or is there some physical tests I should do (like feel if it is mushy, etc)?
Thanks.
Really? You can tell for sure I have to replace it?
If that is the case, can you just replace the wood from underneath? Or do I have to rip up the water barriers under the shingles too?
If the wood needs to be replaced, is it possible to salvage it and just do a proper rotting wood repair? The ones where you sand out everything and then put in epoxy?
I would feel more comfortable doing an epoxy repair rather than replacing since I don't want to have to rip up the water barriers under the shingle
#4 ·
There's really no way to replace that rotted wood from inside. Even if you could do it that way, you woulld still damage the water shield and damage some shingles. I suppose if it's not mushy you could shore that area up with some 2 x 4 braces nailed to the rafters on the underside. That's not an ideal solution but may keep someone from falling through the roof in that area if they are ever up there near that spot. At some point you really need to do it up right by replacing that rot from on top of the roof.
#5 · (Edited)
Thanks for the reply, greatly appreciated. With an epoxy repair, I would just have to sand out the bad stuff, in which case it may be possible to not damage the barriers. If I were to do an epoxy repair AND install the 2x4 supports, shouldn't that be as close to permanent as an original repair? I thought that would last for decades if it didn't get wet again with an epoxy repair and 2x4 reinforcement.
#8 ·
They knew it was leaking for a year and did nothing:eek:
Now there stuck with the only right way to fix it.
The shingles need to go, Tar paper removed, Plywood removed and replaced, new tar paper and new shingles.
Trying to do anything from the inside is just silly and a total waste of time.
Reactions: amodoko
#9 ·
Yeah, my parents are really old now and aren't on top of things as much. If I lived closer to them I would try to get their repairs done quicker. They actually only knew about it around 6 months ago, but I said one year because I'm assuming it has been leaking for about a year since they take a while to notice things, and because there was drywall there before that was masking the leak until the drywall got stained, and then moldy. The drywall is obviously removed in the photo.
I'm going to fix it the right way, just need to do some more research about how to go about this/roof safety/etc.
#10 ·
roof repair
Amodoko, It sounds as if you are trying to find an easy way out. Don't! A band-aid solution won't solve the problem. If the stain are also mold, then you probably are dealing with health issues on top of the leaking roof issue. You don't sound experienced enpugh to fix the problem. You do soul=nd smart enough to get the proper help you require. Do it properly and have piece of mind for you and your parents.
#11 ·
As an FYI....it's not that hard to remove a section of shingles.....I went through that when I was doing the roof on my 2-story addition...Once you get the first one above the area up...the rest are easy.
Follows Joe's advice...do it right the 1st time.
#13 · (Edited)
Yeah, I am going to do it the right way. Am actually at their house right now for Thanksgiving, and I touched the plywood with a broom and it is extremely weak and brittle, definitely needs to be replaced as you guys suggested. I'm just a bit confused about one thing though, when you remove a section of your roof that is in the middle of your roof, do you have to install new underlayment all the way towards the top of the roof even in the unaffected areas to get overlap between underlayments?
To make my question clearer, I read some information about underlayment (specifically the storm shield stuff that is self-adhesive) installation and how you install it kind of like shingles where you start from the bottom of the roof and move up so the sections of underlayment are layered like shingles to get proper water run off. However, when you remove underlayment in the middle of your roof, you can't get that same overlap between the top edge of the new underlayment and the the bottom edge of the old underlayment. So do you just remove the staples/nails that hold the old, salvageable underlayemnt's bottom lip and then reattach it to the new underlayment's top edge to get proper water runoff? Or do you have to remove all the underlayment above the repair to install new underlayment in proper layers?
#14 ·
You just need to expose enough of the roof to remove the wood and to get up under the layer of underlayment above the damaged area.
Shoot high...in other words....don't try to expose just the damaged area...go at least 2-3 rows above...or more...if you start high, it's a lot easier to remove the shingles going down. Once that first row is off...it gets easy.
#17 · (Edited)
This is a perfect reason NOT to have dishes installed on your roof. :no:
And if you must..,buy a mount that is specifically made for roof top mounting.
Or,,have them bolt the dish to the side of your house.That way the siding guy's can deal with it.Hahahahaha
