Does This Look Right To You? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-11-2010, 02:06 PM   #1
Does this look right to you?
This was done less than a year ago, and on the very top of the roof, it appears to be lifting up. We had a very strong wind/rainstorm recently. No roof leaks, but I'm wondering if this is the start to a problem. Any input would be appreciated. Thanks!
sfried01 is offline   Reply With Quote
Old 04-11-2010, 03:35 PM   #2
Residential Roofer
Slyfox's Avatar
It looks to me that you have capped over ridge vent.
The caps that appear to be sticking up have ridge plastic ridge vent under them.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 04-11-2010, 03:41 PM   #3
Thanks for commenting. Unfortunately the terminology is a bit foreign to me. Does that mean it's supposed to be sticking up like that?
Old 04-11-2010, 03:45 PM   #4
Just looked it up.
So, it occurred to me to google it. Please correct me if I'm wrong. It is supposed to be elevated like that because the vents underneath it allow for escape of hot air. Yes?
Old 04-11-2010, 07:18 PM   #5
Registered User
Rewards Points: 526
Yes, as you found out. Some roofers don't run the ridge vent all the way out onto the overhangs, some cut the overhangs for the vent!, and some don't use baffled ones that stop the rain ... http://www.oikos.com/esb/30/atticvent.html
Be safe, Gary
Old 04-13-2010, 08:15 AM   #6
Rewards Points: 150
Looks to me it just needs nailing down. You need to get up there and take a look, and bring a hammer and 6 roofing nails with you.
bernieb is offline   Reply With Quote
Old 04-13-2010, 06:39 PM   #7
Commercial Roofing
AaronB's Avatar
I would only drive a nail through the corners, but not all the way down. Drive them only flush with the existing height of the shingle and caulk the nail head as well as around the penetration in the shingle below.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
