Does This Chimney Flashing Look Correct? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 05-11-2012, 09:32 PM   #1
Does this chimney flashing look correct?
I just had the flashing redone on the rear chimney on my house and I'm concerned the flashing isn't on properly as you would expect from a reputable roofing company.
dmbfanapsu is offline   Reply With Quote
Old 05-11-2012, 09:34 PM   #2
Here is another picture:
Old 05-11-2012, 09:41 PM   #3
Metal Roofing
Rewards Points: 600
It may be installed correctly, but is is not visually pleasing to the eye. The flashing is not laying tightly to the brick, it should be.
Another pic from further away would help. There are far to many folks here that have posted chimney flashing details fit for an art gallery...i will let them point you in the right direction. To me, it could be correct but i know its sloppy.
Gutter spike needs some attention also, its a bit loose
AndyWRS is offline   Reply With Quote
Old 05-11-2012, 09:49 PM   #4
ok i'll have to wait until tomorrow to take another picture, but in the meantime i appreciate the feedback.
Old 05-11-2012, 10:02 PM   #5
Doing This Way Too Long
Rewards Points: 532
While it's not going to make the cover of Counterflashing Quarterly, what's in those pictures appears to be technically correct. There should be a minimum of 2-3" front lap on each step
OldNBroken is offline   Reply With Quote
Old 05-12-2012, 06:33 AM   #6
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
As previously stated, if each piece is overlapped properly, it should work. I would advise pop riveting the pieces more tightly together.
seeyou is offline   Reply With Quote
Old 05-12-2012, 06:59 PM   #7
Rewards Points: 348
Originally Posted by OldNBroken View Post
While it's not going to make the cover of Counterflashing Quarterly, ....
Ah, I remember as a "worked up" teenager, finding these hidden under my brother's mattress. Some great centerfolds!
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 05-12-2012, 07:22 PM   #8
RFN-4A-LVN
Roofmaster417's Avatar
Is it just me or does anyone else get REALLY agitated when your crews/roofers scratch the he** out of the top of the gutters and are too lazy to set those gutter spikes flush ?
Roofmaster417 is offline   Reply With Quote
Old 05-12-2012, 07:55 PM   #9
kwikfishron's Avatar
Rewards Points: 586
It could be that that spike just can’t hold on to the rotted mush anymore, caused by all of the wind driven rain that’s been blasting into that open door flashing for years.
kwikfishron is online now   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
Roofmaster417 (05-13-2012)
Baffling chimney issue… hotot Concrete, Stone & Masonry 15 08-28-2012 08:42 AM
Replacing chimney flashing after new shingles tmiles2246 Roofing/Siding 18 04-18-2011 01:03 PM
Step flashing around chimney... GarageFloorGuy Roofing/Siding 6 02-12-2011 11:09 PM
Flashing around chimney at ridge WillK Roofing/Siding 7 10-20-2010 08:38 AM
Chimney Flashing mfitzsimons Roofing/Siding 4 04-20-2009 10:00 PM
