Do These Porch Columns Provide Any Support? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-05-2013, 10:42 PM   #31
r0ckstarr's Avatar
Rewards Points: 1,998
Finished everything including primer this afternoon. All that is left is paint. Thanks for the help and info. I wasn't sure how to go about it at first.
r0ckstarr is online now   Reply With Quote
The Following User Says Thank You to r0ckstarr For This Useful Post:
oh'mike (03-06-2013)
Old 04-29-2013, 03:56 PM   #32
kimberland30's Avatar
If you have a chance, could you please post a picture of what you did to the base of the column you replaced? We had a similar issue with our porch posts rotting at the bottom and they are now supported by ugly concrete blocks. Did you use the post bases that JoeCaption posted? That might be a solution for us and I wanted to see how it worked out for you.
Thanks!
kimberland30 is offline   Reply With Quote
Old 04-29-2013, 04:28 PM   #33
r0ckstarr's Avatar
Thanks!
Sure. Here's the thread detailing the repair.
Porch column repair
kimberland30 (04-29-2013)
Old 04-29-2013, 04:33 PM   #34
Yay, thank you so much! That thread didn't come up when I did a search.
The Following User Says Thank You to kimberland30 For This Useful Post:
r0ckstarr (04-30-2013)
Replacing basement support columns TonyToronto Building & Construction 3 12-16-2012 01:04 PM
Sunroom extension support footings repair + cost gentlemansbeard Building & Construction 11 03-25-2011 03:40 PM
Building a front porch and have questions... SolidStateS15 Building & Construction 9 07-10-2010 05:16 PM
Replacing Porch Columns mcwolfe6 Building & Construction 8 05-12-2010 07:51 PM
Painting square porch columns katie74 Painting 2 05-13-2009 01:37 PM
