Do Roof Shingles Go Bad? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-07-2006, 12:15 AM   #1
Do roof shingles go bad?
Does anyone know if shingles go bad? They're timberline 40yr shingles. The problem is they've been sitting outside uncovered on pallets for probably about a year. Can they get damaged like this? My theory is they're made to sit outside so it can't really hurt them. They arn't brittle or crushed.
Tmb9862 is offline   Reply With Quote
Old 10-07-2006, 12:57 AM   #2
my only experience with this sort of thing is the sticky strip on the back side of the shingles tend to stick together is they sit out in the sun and heat. I am not familiar with timberline 40yr, but I had this problem with some 3 tab 30yr once but they sat out for longer than a year.
Roscoe is offline   Reply With Quote
Old 10-07-2006, 09:55 AM   #3
Commercial Roofing
AaronB's Avatar
Ummm, like Roscoe said...but I would consider them already a year old.
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Shingles on Low Pitched Roof? sandyman720 Roofing/Siding 2 08-01-2007 10:47 PM
shingles on a low-pitch roof jdbaum Roofing/Siding 9 07-07-2007 08:59 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 11:12 PM
replace tar & gravel roof with shingles & torch down rt1035 Roofing/Siding 4 12-17-2005 06:39 PM
