Do I Need Ridge Vent For A Small Porch Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-06-2011, 09:17 PM   #1
Cow
Do I need ridge vent for a small porch roof?
I have a small, probably 8x8 porch roof that'll have vented soffit around it. Since it's open to the rest of the main house attic, I didn't know if it'd vent with the rest of the house or if it needed it's own ridge vent as well?
Also, does anyone know the best place to order Shingle Vent II online? It seem like a pretty good product...
My local lumber yards only carry the plastic corrugated ridge vent you roll out. It only flows about 12-13 cubic inches per foot, versus the 18" or so Shingle Vent II does.
Thanks for the help.
Cow is offline   Reply With Quote
Old 07-07-2011, 11:58 AM   #2
Next Time...New Build
Rewards Points: 150
Is it a heated porch? If it is just an open air porch, I do not think you need vent, much less the vented soffit.
RickyBobby is offline   Reply With Quote
Old 07-08-2011, 08:43 PM   #3
Cow
It's an open porch. I was planning on using vented soffit just so it would match what was around the rest of the house.
And, in case it helps someone else I ordered Shingle Vent II through modern builders supply online. They'll only sell to individuals if you order online though, otherwise you need to be a business or contractor.
Old 07-08-2011, 09:24 PM   #4
Rewards Points: 252
I assume air can get in through the soffits and then into the main attic and out a ridge or gable vent? If so, i imagine you are fine.
shazapple is offline   Reply With Quote
Old 07-09-2011, 12:44 AM   #5
Lowes, at least in my area, NW Suburbs of Chicago, stocks the Shingle Vent II Ridge Vents.
Ed
Ed the Roofer is offline   Reply With Quote
Ridge vent on 2:12 slope cathedral roof DaveM75 Roofing/Siding 5 09-28-2016 03:47 PM
Shingling over ridge vent -details needed jogr Roofing/Siding 4 11-06-2009 05:47 PM
Where porch roof meets wood siding Trish99 Roofing/Siding 14 07-16-2009 08:31 AM
problem with ridge vent magic Roofing/Siding 19 07-06-2009 11:38 AM
Ridge Vent on a Shed jokiddjr Roofing/Siding 5 03-14-2008 03:22 PM
