Do I Need A Permit To Repair My Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-08-2009, 02:42 AM   #1
Do I need a permit to repair my roof?
In unincorporated King County, basic roof repairs or reroofing of existing buildings typically does not require a permit. A permit is required if a heavier roof covering, such as a tile roof, replaces an existing composition or wood shingle or shake roof. If the roof structure, such as trusses or rafters, is altered or replaced, a permit is required. For commercial structures, the fire resistive rating of the roof must not be diminishe
shanemcguire1 is offline   Reply With Quote
Old 04-08-2009, 03:41 AM   #2
Contact your local County Building Department to see for sure.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-13-2009, 04:19 AM   #3
What is the best shingle to use when reproofing a house?
Old 04-13-2009, 07:13 AM   #4
Most areas do not require permits for roofing, unless plywood sheathing is replaced. Then a permit is needed in our area.
The best roof you can install has no shingles, it is a standing seam metal roof, expensive, but can last 50-100 yrs. Better grades of shingles cost only slightly more per square than the basic 3 tab 20 yr shingle. Dimensional(arcthitectural) shingles usually start at 30 yr, and the installation cost is the same.
Old 04-13-2009, 11:30 AM   #5
Rewards Points: 1,910
I'd go with one of the higher rated (wind speed and lifetime ratings) Dimensional (architectural) shingles. Right now you might also be able to get a 30% tax credit if you go with one energystar listed.
Old 04-14-2009, 07:05 AM   #6
Friends,
Thanks for the information. According to your suggestion I search for some online resource for them same. Whenever I find out some good resource I share that info with you.
Thanks,
Old 04-16-2009, 02:47 AM   #7
As I am search on Google for find out Roof Repair, I find out a company who provide roof repair, roof maintenance and roof cleaning services for commercial, industrial and residential in Kansan City.
Last edited by Ed the Roofer; 04-16-2009 at 02:18 PM. Reason: Edited out stupid referral link.
Old 04-16-2009, 09:15 AM   #8
ccarlisle's Avatar
Oh, OK.
I thought there was a question there somewhere, didn't find one, so thought there was a glitch - but if you're just letting us know, great...
Permits are a second opinion on some things that may affect safety of your home or yourself: plumbing, electrical HVAC and/or structure. Permits here can be your best friend.
Some people don't pull them due to greater tax liabilities...don't know about this aspect, just the way I see it.
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 04-16-2009, 09:58 AM   #9
Safe, Most of the Time!!
brokenknee's Avatar
Aaaah no, that may be true in your area, but not in all, best check it out with the local building authority.
I do agree with your choice of roofing material, only drawback I can see to a metal roof is they can be a little noisy during a storm. I wish I had one on my roof.
If using asphalt shingles I would definitely go with the architectural single, if you go to sell your house it will make it more attractive to the buyer.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline   Reply With Quote
Old 04-16-2009, 10:12 AM   #10
I had a metal ridge vent on my last house
I couldn't rip that noisy sucker off fast enough
Between rain, sleet & acorns falling on it
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
Metal Roof Repair Questions bruce3404@hotmail.com Roofing/Siding 3 09-17-2008 11:00 PM
roof repair questions Salvatorparadise Roofing/Siding 2 02-19-2007 09:22 PM
