-   -   Do I need a permit to repair my roof? (http://www.diychatroom.com/f9/do-i-need-permit-repair-my-roof-42032/)
shanemcguire1 04-08-2009 02:42 AM
In unincorporated King County, basic roof repairs or reroofing of existing buildings typically does not require a permit. A permit is required if a heavier roof covering, such as a tile roof, replaces an existing composition or wood shingle or shake roof. If the roof structure, such as trusses or rafters, is altered or replaced, a permit is required. For commercial structures, the fire resistive rating of the roof must not be diminishe
Ed the Roofer 04-08-2009 03:41 AM
Contact your local County Building Department to see for sure.
Ed
shanemcguire1 04-13-2009 04:19 AM
What is the best shingle to use when reproofing a house?
Just Bill 04-13-2009 07:13 AM
Most areas do not require permits for roofing, unless plywood sheathing is replaced. Then a permit is needed in our area.
The best roof you can install has no shingles, it is a standing seam metal roof, expensive, but can last 50-100 yrs. Better grades of shingles cost only slightly more per square than the basic 3 tab 20 yr shingle. Dimensional(arcthitectural) shingles usually start at 30 yr, and the installation cost is the same.
jogr 04-13-2009 11:30 AM
I'd go with one of the higher rated (wind speed and lifetime ratings) Dimensional (architectural) shingles. Right now you might also be able to get a 30% tax credit if you go with one energystar listed.
shanemcguire1 04-14-2009 07:05 AM
Friends,
Thanks for the information. According to your suggestion I search for some online resource for them same. Whenever I find out some good resource I share that info with you.
Thanks,
shanemcguire1 04-16-2009 02:47 AM
As I am search on Google for find out Roof Repair, I find out a company who provide roof repair, roof maintenance and roof cleaning services for commercial, industrial and residential in Kansan City.
ccarlisle 04-16-2009 09:15 AM
Oh, OK.
I thought there was a question there somewhere, didn't find one, so thought there was a glitch - but if you're just letting us know, great...
Permits are a second opinion on some things that may affect safety of your home or yourself: plumbing, electrical HVAC and/or structure. Permits here can be your best friend. :wink:
Some people don't pull them due to greater tax liabilities...don't know about this aspect, just the way I see it.
brokenknee 04-16-2009 09:58 AM
Aaaah no, that may be true in your area, but not in all, best check it out with the local building authority.
I do agree with your choice of roofing material, only drawback I can see to a metal roof is they can be a little noisy during a storm. I wish I had one on my roof.
If using asphalt shingles I would definitely go with the architectural single, if you go to sell your house it will make it more attractive to the buyer.
Scuba_Dave 04-16-2009 10:12 AM
I had a metal ridge vent on my last house
I couldn't rip that noisy sucker off fast enough
Between rain, sleet & acorns falling on it :no:
