Do I Cement Sphalt Shingles To Valley? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-05-2012, 11:07 PM   #1
Do I Cement Sphalt Shingles to Valley?
Moving along on my roofing project with Certainteed Presidential Roofing.
The instructions call for a 3" wide bed of asphalt roofing cement to be used under the shingles to attach them to the valley metal. The instructions don't give any more instruction about what type of roofing cement. So I started researching here in the search option for some suggestions.
I learned that some (most?) don't recommend using any roofing cement at this application point on the roof. Is that true? Why not?
If I should use roofing cement, what type of Henry product would you recommend? (since Henry brand is readily available around here)
Thanks!
Bill
woops! Sorry for typo in Subject line. I can't seem to edit it.
wmarazita is offline   Reply With Quote
Old 09-05-2012, 11:12 PM   #2
Rewards Points: 14,012
Never heard of that one. I just use Strom And Ice shield and have never had a leak yet.
Old 09-05-2012, 11:56 PM   #3
This is the instruction that I have:
Old 09-06-2012, 04:59 AM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
No, you do not cement the valley shingles. Just cut the tops correctly.
Do I Cement Sphalt Shingles to Valley?-clipped-valley-shingles.jpg   Do I Cement Sphalt Shingles to Valley?-clipped-valley-shingles-2-.jpg
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Windows on Wash (09-06-2012)
Peel and Stick Veneer and Contact Cement GreggG Kitchen & Bath Remodeling 6 02-23-2015 05:30 PM
Cement board at tub lip Homerepairguy Plumbing 18 02-22-2013 09:13 PM
cement board on top of cement brim in washroom avi Remodeling 9 09-08-2011 07:05 PM
Energy Star Qualified Asphalt roofing shingles? Scuba_Dave Roofing/Siding 50 09-28-2010 02:25 PM
Best cement(brand) to seal asphalt shingles to copper valley oldgrunt Roofing/Siding 2 12-07-2008 01:27 PM
