Do Architectural Shingles Way Considerably More Than A Cedar Shake Roof? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-25-2012, 01:47 AM   #1
Do architectural shingles way considerably more than a cedar shake roof?
Confused new member here.
I live in Alaska. My 32 year old shake roof (house built in 1952) needs replacing. I'm considering replacing the cedar with architectural shingles, but I'm concerned about the weigh difference between the two.
Two different roofing contractors have told me opposing views--one says the old cedar shake roof and all its contents ( shakes, felt, whatever) doesn't weigh much less than a new architectural shingled roof and all its contents.
The other contrator says the difference between cedar and shingle is more than double.
Anyone care to chime in? I hate to add a whole lot of weight to the roof of my old house.
Thanks!
tork is offline   Reply With Quote
Old 06-25-2012, 06:13 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
They are not more than double.
They usually weight about 2 - 3 lbs per square foot and there is some variability with rain and moisture accumulation.
It is going to be a near toss up between most of the dimensional shingles out there now and cedar.
Depends on the thickness and type cedar as well.
Old 06-25-2012, 11:16 PM   #3
Registered User
Rewards Points: 5,212
http://www.mcvicker.com/resguide/page011.htm
http://www.certainteed.com/learning-...ofing/?qid=149
Gary
Old 06-28-2012, 08:36 PM   #4
Rewards Points: 850
well lets see = dimensional shingles weigh 240 pounds per square. ofcourse you can buy dimensional shingles that weigh more. shakes = 5 bundles per square. each bundle weighs about hmmm about 30 pounds = 150 pounds per square, ofccourse thats dry, we all know when wood get wet it weighs a lot more. you also have #30 felt = 30 pounds so all and all the dimensional shingles might weigh more when shakes are dry but when there wet they might weigh more. most houses are rated for around 1000 pounds per square weight. but now if you have shakes then you should have spaced sheeting which means you need plywood but still youll be fine. best thing is to contact your local building department and find out what you can put on.
hotrod351 is offline   Reply With Quote
Old 06-29-2012, 08:15 AM   #5
Don't forget that shingles gain weight with water as well. Not to the same extent wood does but they do hold water.
Architectural shingles to buy vs. regular vkerns Roofing/Siding 24 08-04-2016 05:31 PM
Proper transition between shed roof and shingled roof? aribert Roofing/Siding 9 04-12-2012 04:17 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 11:02 PM
Improperly installed roof ktpersh Roofing/Siding 1 05-15-2008 07:57 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 07:17 AM
