DIY Roof Replacement - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-04-2014, 06:26 PM   #31
Rewards Points: 365
Who knows if anyone is pro? Seems the only thing around here are big egos. You're saying 3/4" plywood is bad advice? I have 3/4" decking already why wouldn't i replace it with the same thing. You make no sense half the time. Only a fool would take this forums advice. Most of your responses are attacking other people "You clearly don't have a clue."
Your so called pros are hacks. No one mentioned the harness of scaffolding. You are just mad because i showed you up. You should know about the harnesses too, it is required by usa safety boards!
begal is offline   Reply With Quote
Old 08-04-2014, 06:34 PM   #32
roofermann's Avatar
Rewards Points: 401
roofermann is offline   Reply With Quote
Old 08-04-2014, 07:45 PM   #33
Metal Roofing
Rewards Points: 600
You sir, are a jacka**.
FYI, there is hundreds of years of experience in the roofing industry represented here. The only fool is you.
AndyWRS is offline   Reply With Quote
The Following 2 Users Say Thank You to AndyWRS For This Useful Post:
mem (08-14-2014), roofermann (08-11-2014)
Old 08-04-2014, 08:09 PM   #34
kwikfishron's Avatar
Rewards Points: 798
Be nice people....Just a friendly reminder from our posting rules.
Users shall treat each other with respect at all times on DIYChatroom.com. Name calling, personal attacks, or other inappropriate behavior will not be allowed and may cause your account to be banned.
kwikfishron is offline   Reply With Quote
Old 08-04-2014, 08:22 PM   #35
Doing This Way Too Long
Rewards Points: 532
Methinks this thread has been a tad hijacked. I hope the OP got any advice or info before the ****show began.
Here we go again
Roofing 101 - Think Like Water
OldNBroken is offline   Reply With Quote
Old 08-04-2014, 09:19 PM   #36
The OP (moi) is having a good laugh at the silliness. However, most of you have given me valuable info. It is much appreciated.
Thank you,
Dave
KSGolfnut is offline   Reply With Quote
The Following User Says Thank You to KSGolfnut For This Useful Post:
roofermann (08-05-2014)
Old 08-04-2014, 09:28 PM   #37
Rewards Points: 532
Thank you,
Dave
Good, because we are too.
Old 08-04-2014, 09:32 PM   #38
An old Tradesmen
Rewards Points: 7,808
Originally Posted by kwikfishron View Post
Be nice people....
You were right, I was wrong.
Tags
asphalt , decking , roof , shakes , sheathing
Roof replacement contract stack316 Roofing/Siding 20 03-03-2013 08:34 PM
Need help deciding on flat roof replacement... BeckyFL Roofing/Siding 1 10-17-2011 10:43 AM
rubber roof over tar & thoughts on quote wfmrules3 Roofing/Siding 13 10-16-2011 09:00 PM
What will be typical cost of roof replacement miamikk Roofing/Siding 10 09-11-2011 08:48 AM
slate roof replacement w36cowgirl Roofing/Siding 9 03-12-2010 01:35 PM
