DIY Roof PICS For Your Enjoyment - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-09-2010, 09:10 PM   #1
DIY Roof PICS for your enjoyment
What a difficult demanding job, I rather do anything else on a house.
Some mid progress pics:
amdspitfire is offline   Reply With Quote
Old 09-09-2010, 09:24 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
looking good you are nailing the roof sheathing thru the strapping and into the rafters right?
Tom Struble is offline   Reply With Quote
Old 09-10-2010, 12:08 AM   #3
Rewards Points: 956
wow good stuff. thanks for sharing. wish i was that handy
federer is offline   Reply With Quote
Old 09-10-2010, 08:20 AM   #4
Doing This Way Too Long
Rewards Points: 532
Bah, no need to hit the rafters as long as the existing skip sheeting is secured well.
At least the roofdeck looks clean and straight for the age of the bldg. Nice neat work you're doing there. Only thing I hate seeing is that debris landing on the ground. That just makes your job three times harder. If you can at all help it, get it straight into your truck/trailer/container directly from the roof. Makes the job considerably "easier".
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
seeyou (09-10-2010)
Old 09-10-2010, 11:00 AM   #5
Rewards Points: 956
dont they have those construction debris bags things thats like a dumpster but its a giant plastic bag that you can rent?
Old 09-10-2010, 11:19 PM   #6
Registered User
Rewards Points: 5,516
Use a roofing shovel to get under the shakes and paper, roll it up with a helper into a "sod roll" about 7-8' long, section cut it with shovel, heave it down into dumpster. No handling of individual shakes other than around vents.
Add a valley jack rafter in that 3' span, at the first longest bottom one missing. Cut back the ridge vent with baffle now for your passive venting system: http://files.buildsite.com/dbderived...rived20936.pdf
http://www.airvent.com/homeowner/pro...it-specs.shtml
Imperative to leave the required 1/8" gap between osb sheets, otherwise run the saw to rip it now: http://osbguide.tecotested.com/pdfs/en/el812.pdf
Gary
Old 09-11-2010, 11:37 AM   #7
Registered User
Just an added thought as it was late for me last night...
"Bah, no need to hit the rafters as long as the existing skip sheeting is secured well." ----- you would think that would be true. When the house was framed the Codes for shear were mild on a roof. Ply or osb sheathing under skip sheathing was not required as it is today in most areas. The minimum 8d nails on the 1x4 at 2 per rafter was usually not enforced. I see 1-2-1-2 and 2-1-2-1 in your nailing pattern, add some as OldNbroken said. The osb needs minimum 6d nails into the rafters at least 6/12" on center to meet today's Code. This 2" nail needs to be secured in full wood, not air for the remainer of length- 3/4", or it will not get the required withdrawl it needs for shear as tomstuble said. Especially in the seismic zone you are in. The tail overhang blocking need a row as each gable for building shear flow. Be careful up there!
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
seeyou (09-11-2010)
Old 09-14-2010, 12:11 AM   #8
Rewards Points: 956
wow i have no clue what you are talking about lol
Old 09-14-2010, 06:03 AM   #9
Grumpy's Avatar
Rewards Points: 540
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
I wouldn't have piled up the garbage along the fence like that and I wouldn't have use OSB.
I saved the picture of the trash to show future customers what we wouldn't be doing.
-Grumpy http://www.illinoisroofinspections.com
The information found in this post is not to be considered legal advice. The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 09-14-2010, 01:32 PM   #10
My edges weren't originally going through rafters but always went through the strapping .. and I didn't for the garage that's visible from underneath! Should I cut the osb and redo the rows so the edges land on the rafter?
As I progressed I got all my edges on the rafters even if I had to cut the osb slightly.
Yah, almost 50yr old house, it's mostly in decent condition. I started the job on a whim and had what I thought was plenty of room on the side of the house. Kept dumping till I could walk off the roof .
Ended up getting a huge 43cu yard debris box, filled it to the brink. Luckily the garbage ppl loaded the crap for me for just $550 including box/removal.
Gary
Good links, thanks. I wasn't leaving the gap for the ridge vent originally but did midway through. Got to cut some places now. When it's your first time doing it, you learn a lot of things as you progress.
Gary
Making sure I got the 2 nails per rafter on the 1x4's, and adding some so the edge of the osb always land on them.
Already had an accident, stepped wrong, went through the slats past my knee. My luck there was a nail sticking out right there too. Pretty little nail hole in my thigh plus my legs is still stiff/sore couple days later.
Plywood instead of OSB?
Hahahaha
Strange Winter Roof Leak Dragon Roofing/Siding 16 10-09-2009 06:06 PM
Replace roof or not? with pics billmee Roofing/Siding 4 08-09-2009 10:23 AM
Addition and Roof Replacement lebeld Roofing/Siding 4 01-04-2009 06:11 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Edge of roof deteriorated, how to repair? (pics) diymonkey Roofing/Siding 3 06-23-2007 01:02 AM
