DIY Metal Roof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-18-2010, 08:41 PM   #1
DIY Metal Roof
Last month, we bought a moldy old 1958 split level. Everything needs to be refinished and re-done. Previous roof was shingles, but we quickly learned nto to use shingles (without expecting catastrophic failures) on this low-slope roof.
Enough intro, we will begin standing seam metal roof installation as soon as permit dept says we can. Applying this week. We have measured and re-measured, drawn it out, found a supplier, and bought the tools (we think) we need. We're using ridge vents. We're using grey boots. Any installation tips before we get started?
Tried to upload pic, but no good. I will see if I can do it later if anyone is interested.
harringtona1 is offline   Reply With Quote
Old 10-18-2010, 08:57 PM   #2
jlhaslip's Avatar
Rewards Points: 390
What pitch?
Link us to the metal roof manufacturer's site for the installation guidelines.
Be certain to follow their instructions to the "tee", or the warranty is void.
Do you have a rag, vice grip pliers and a rope for getting the pieces up to the roof?
Plan on laying down black roof paper under the metal because it sweats when the climatic conditions are right.
Besides, it gives you an extra layer of protection.
Sounds like you will need to add some ventilation to the attic as well to avoid further issues with mould.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
Old 10-19-2010, 08:25 PM   #3
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Hope these details help. http://www.albertsroofing.com/Tin%20...to_gallery.htm And I have many others at this online photo gallery. http://www.rooferscoffeeshop.com/pho..._list.asp?u=30
tinner666 is offline   Reply With Quote
Old 10-20-2010, 10:26 AM   #4
keep it coming!
Thanks for the notes, guys. The slope is 1.5/12, by the way.
I looked at those cleats. I had forgotten that we will also be installing a solar pool heater on part of the roof. Did you make those yourself?
Old 10-20-2010, 06:29 PM   #5
Pro Slate Roofer
tinner666's Avatar
There is very little that I don't hand make, or use a break for.. Not sure of the solar panels, but it could be that a heavier metal cleat could handle the load, but wind could be an issue depending on where you are.
I assume your're talking about the accessory cleats?
A solar panel bracket looks like this one and I believe if could be incorporated into the roof some way.
DIY Metal Roof-accesssory-cleats-6-.jpg   DIY Metal Roof-solar-panel-bracket-3-.jpg
Old 10-20-2010, 06:32 PM   #6
Pro Slate Roofer
tinner666's Avatar
If you bought hand tongs, I hope you got the Malco S'3. Straight ones have nearly zero use for metal roofing.
Old 10-20-2010, 10:48 PM   #7
Tom Struble's Avatar
Rewards Points: 2,002
http://www.s-5.com/home/index.cfm
Tom Struble is offline   Reply With Quote
Old 11-08-2010, 08:45 AM   #8
Well, we are 9 days into our metal roof project - the high roof. Interesting that nobody mentioned that the real work is in prepping the roof! Removing shingles, tar paper, nails left from the tar paper before the old tar paper, rotted boards, rotted rafters and rafter tails to replace, removing blow-in insulation, installing new insulation, removing some old giant cementitious vent from an old furnace, repairing crap electrical work with 3 days of intermittent rain needing a giant tarp from Harbor Freight... We'll finish buttoning it up next weekend. Metal roof doesn't even get on until the following weekend. But in the meantime, we are busily hemming each panel - that is some tedious work. This project has a LOT of lessons!!
Old 11-08-2010, 09:04 PM   #9
My wife and my neighbour have been pushing me to consider a metal roof, but until a few weeks ago, I simply ruled any kind of metal roofing out as being out of the realm of even avid DIY'ers. I guess seeing me up there patching the existing three-tab shingles several times per year has lost its entertainment value for them, so I have finally started seriously looking in to metal roofing.
I, for one, would love to see photos of the work you're doing!
KAdams4458 is offline   Reply With Quote
Old 11-12-2010, 01:21 AM   #10
Pictures
I would love to see the pictures too. I have been told that metal roofs are very durable and I would love to put one on my house but didnt think it was a DIY deal. Please let me know how hard it was and what all was needed. Thank you so much!!!!
Medic507 is offline   Reply With Quote
Old 11-17-2010, 08:13 AM   #11
I'd love to help out. FYI, in Florida, if you have a very low-slope roof, you can't even use shingles. That made our decision easy. We have some of the tar paper up now and will begin with panels this weekend. I will post pics early next week. Keep your fingers crossed!
Proper way to install chimney pipe in metal building roof jonblack Building & Construction 15 01-31-2012 11:50 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 03:58 PM
Gable Trim on Metal Roof jm1542 Carpentry 2 11-19-2009 04:58 PM
How to vent eaves if no overhang, metal roof, Texas? pj99 Roofing/Siding 7 06-04-2009 03:58 AM
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 05:08 PM
