Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-20-2005, 01:25 PM   #1
Disconinuted Shingle
I need to find a match for my shingle that has been discontinued. I have a Firehalt Shingle - GS Metric Hunter Green SHawdowline. Any idea on how to find a good match or even locate an company that carries some of this "old" product? Noen of the local stores (Home Depot, Lowe's, etc.) have anything close!
nlcotten is offline   Reply With Quote
Old 03-20-2005, 04:52 PM   #2
aka:awesomedell
Send a message via MSN to housedocs
How old are the shingles and how much area do you have to cover?
All you need is ignorance and confidence and success is assured. - Mark Twain
housedocs is offline   Reply With Quote
Old 03-20-2005, 10:09 PM   #3
Commercial Roofing
AaronB's Avatar
Might need to replace all of it, huh?
www.roseroofing.net OUR SYSTEMS CAN PAY YOU BACK!
SEAMLESS Polyurea Roofing for Metal, Roof Repair and Sealing, Roof Leak Repair, SEAMLESS Commercial Spray Foam Insulation, SEAMLESS Commercial Roofing, SPF, Industrial Insulation and Coatings, Energy Efficient Roofing, Roof Maintenance.
AaronB is offline   Reply With Quote
Old 03-21-2005, 12:22 AM   #4
aka:awesomedell
Well I didn't want to burst his bubble right off the bat. But yeah that's kind what I was thinking too, but you never know, he might get lucky. That's a OC product isn't it Aaron? That's what I was thinking anyway, we don't do a tremendous amount of roofing and we tend to use Tamko whenever we can. Most of the shingles we used are made here in Mo, so it's a matter of spending our $$ as close to home as possible.
Old 03-21-2005, 12:19 PM   #5
Commercial Roofing
AaronB's Avatar
I do not know this mfg.
Old 03-21-2005, 04:42 PM   #6
aka:awesomedell
Tamko or OC (Owens-Corning)
Old 03-22-2005, 07:54 AM   #7
Commercial Roofing
AaronB's Avatar
That would explain it. I use GAF or certainteed when my color gaf is not available.
Old 03-22-2005, 09:44 AM   #8
aka:awesomedell
But you have heard of the other two manufacturers haven't you Aaron.
Old 03-22-2005, 10:15 AM   #9
Commercial Roofing
AaronB's Avatar
Tamko and Owne's Corning? Of course, but am not familiar with their lines.
More On This Topic
There a few things more satisfying and secure than settling in for winter under a brand new roof. If your roof needs repair or replacement, plenty of area roofing contractors can help you. What do you look for in a new roof? Find out here! Read More »
Tin roofs have been around for centuries. The tin roof at Monticello, Jefferson's home, is still in good condition, despite being the one originally placed on the house when it was first built in the 1800s. Occasionally, it is necessary to pop one or... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, we will checking the roof for loose or missing shingles. To check for any loose or missing shingle, you just want to take a close look at your roof. If there are any areas that might look... Read More »
At some point, you may need to replace the flashing around the vents in your roof. If you aren't afraid of heights, you can replace the flashing yourself. Make sure you don't fall. Also, wear gloves to protect your hands from the sharp edges of the vent... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip we'll be calculating shingles. To calculate the number of bundles of shingles for a basic gable roof first we need to measure the length and the width of the rectangular areas that is adding... Read More »
Comp shingle recommendations needed Arndavis Roofing 7 06-07-2008 10:01 PM
CertainTeed starter shingle ? MACCC Roofing 2 04-20-2007 03:26 PM
Inexpensive Shingle Cutters... MoparAutoworks Roofing 5 10-13-2006 10:16 AM
Cost of Torch Down vs. Shingle Misha Roofing 2 10-02-2006 04:21 PM
Shingle Pattern gilberte Roofing 7 09-05-2005 04:37 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
