Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 05-20-2010, 04:39 PM   #1
Dirty Roof
We have a branch that has been hanging over our roof for some years now. Rather close to the roof and almost touching it. I have finally convinced the city to come remove the limb this week (it's on the city tree belt). But over the years it has made to roof look terrible. Some spots are discolored and black. Dark around the area of where tree limb covered it. See the photo below of the roof...
My question is this.. Is there anything I can buy to clean this up and restore the look of the roof, like some sort of cleaning agent. OR am I stuck with having to replace the shingles to get my roof looking clean again?
mklaro is offline   Reply With Quote
Old 05-20-2010, 06:24 PM   #2
Shut in w/o Home
seeyou's Avatar
Dirty Roof
Don't do anything for a while. The stain is likely algae growing in the constant shade/moisture of the tree limb. A little ray of sunshine might solve your problem.
seeyou is offline   Reply With Quote
The Following User Says Thank You to seeyou For This Useful Post:
Tom Struble (05-20-2010)
Old 05-20-2010, 09:29 PM   #3
Dirty Roof
1/3 gallon bleach,1 gallon parts water,1/4 cup trisodium phospate.Spray on see what happens,usually works rather well.Water down plants that will be affected by run-off.After run a nice bead of powdered Tide laundry soap down ridge and let rain do the rest,or if it's not going to rain for a while sprinkle it down a bit with a hose.
johnk is offline   Reply With Quote
The Following User Says Thank You to johnk For This Useful Post:
Need opinion on this roof profenx Roofing 14 10-12-2010 01:56 AM
Putting a new flat roof on a 3600 sf home Jean3 Off Topic 2 04-09-2010 01:35 AM
The moving Ice Dams after using a roof rake ?? Canufixit Roofing 9 02-05-2009 08:33 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
