Didn't Use 6 Nails As Stated In Contract - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 06-24-2012, 09:09 AM   #1
didn't use 6 nails as stated in contract
roofer was suppose to use 6 nails per shingle. He use five with a 16-21 inch gap between the forth and fifth nail. We gave him the opportunity to add more nails but he waited a week and the self sealing tabs glued down the roof. It is a $6,300 job we still owe him $5,300. Should we demand he redo the roof before paying him the balance. We did not expect the guy we contacted with to sub our job out to another contractor who used undocumented workers to our roof job. They also did this rip down job on a day when rain was eminent at lightning speed.
moonraker is offline   Reply With Quote
Old 06-24-2012, 09:20 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Who specified to use 6 nails?
What is the pitch of the roof?
Old 06-24-2012, 09:28 AM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Refuse to pay him and I will guarantee you will have a lien placed on your house. On a $6,300 job he didn't make much to start with, the materials was the bulk of the cost. Why don't you try to roof as hot as it is now.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 06-24-2012, 09:36 AM   #4
Rewards Points: 12,878
Why the 6 nails, is this a high wind area?
If not then 5 is enough, for a normal install only 4 are required.
Old 06-24-2012, 09:58 AM   #5
Rewards Points: 470
easy check with the code and see what it is sopose to be ?? If more than make him put more nail's if not that pay him. Have it inspected ?? that will let both of you know .
del schisler is offline   Reply With Quote
Old 06-24-2012, 10:35 AM   #6
Rewards Points: 166
what does that mean ?
Fix'n it is offline   Reply With Quote
Old 06-24-2012, 10:42 AM   #7
16'' to 21'' between nails?? More important.. What kind of shingle do you have?
CopperClad is offline   Reply With Quote
Old 06-24-2012, 11:09 AM   #8
biggles's Avatar
Barrington Project House on TOH did a lab test on 4 vs 6 nails per shingle. 4 will hold down in 50MPH then 6 will hold 100MPH wind.6 nails go just up from the slits on the each shingle 1-2-2-1. and the lenght of the nail has to be matched to the type of shingle thickness
The Following User Says Thank You to biggles For This Useful Post:
Fix'n it (06-24-2012)
Old 06-24-2012, 11:14 AM   #9
Still doesn't explain how there is 16'' to 21'' between the 4rth and 5th nail on a standard 36'' shingle.. Especially since OP is claiming they did use 5 nails?
Old 06-24-2012, 11:19 AM   #10
bbo
To answer your original question.
How will the court system there interpret your signed contract? I guess a lawyer would be a good place to start, followed up by a judge.
bbo is offline   Reply With Quote
Old 06-24-2012, 06:08 PM   #11
747
registered
747's Avatar
Rewards Points: 534
boy i don't know. Your claiming breach of contract. Contract said 6 he only installed 5.... 5 nails are sufficient. I think the court would give him something. What is small claims limit in your state? I think the court would award him 4000 dollars. He is definitely getting something for the roof. You better decide what your going to do. He slaps a lien he is now in the driver seat. You hit him with small claims lawsuit your in driver seat he can't slap a lien. I personally think 5 is OK. But i do understand your dilemma. For a house roof. You should have went with a guy who was manufacture certified for the shingles you wanted to use. Example certain teed master certified installer.
747 is offline   Reply With Quote
Old 06-24-2012, 07:24 PM   #12
Rewards Points: 626
OK, first are you in a high wind prone zone? i.e. can have sustained gusts over 100 MPH. If not don't worry. Second does your roof leak? If the answer is No Don't worry about it. Third if he installed according to Manufacturs recomend best practices. you don't have a leg to stand on. And last Did you check his workers for their green cards? If not your Assuming and putting your nose were it does not belong.
Nailbags is offline   Reply With Quote
Old 06-24-2012, 07:26 PM   #13
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Just adding a nail above another nail over the key does no good. The nails are to spaced about 1" to each side of the key way. If wind ever put pressure on the one above another one, it would be too late to have any holding power. The damage is already done.
tinner666 is offline   Reply With Quote
The Following User Says Thank You to tinner666 For This Useful Post:
Tom Struble (06-24-2012)
Old 06-24-2012, 08:08 PM   #14
Doing This Way Too Long
Rewards Points: 532
Never did find out what type of shingle it even is. I'm assuming it's a laminate if the nailing pattern is so wonky.
OldNBroken is offline   Reply With Quote
Old 06-24-2012, 08:53 PM   #15
Tom Struble's Avatar
Rewards Points: 2,002
doesn't have to be a high wind area,could be a steep slope or mansard install calls for 6 nails on some shingles,some use 7-9
guy had a contract calling for 6 nails how is 5 good enough
Tom Struble is offline   Reply With Quote
$1,000 in extra charges beyond contract Soliel Flooring 2 07-27-2011 06:19 PM
Contract breach madoff12 Building & Construction 38 02-27-2011 02:52 PM
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 07:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 11:05 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 11:31 PM
