I have a leak in my attic that I think is coming from or around the chimney. I have posted some pictures below. The most obvious problem I see is that the caulk/sealant around the chimney flue has pulled away from the cap near the places you see rust. I plan to sand that rust away and reseal. Advice welcome.
I have also included pictures of the flashing (north side and east side). I don't see any problems but I don't have a lot of expertise. Does anyone see a problem?
must be flashed under that siding and thats hard to see. you could try runing water on the top and have some one inside look to see if water comes in but as for the siding well thats a whole different deal. you could also soak down around the base of the siding and roof and see if it comes in. it would be good for you if it didnt because you would have to pull that siding off to see whats going on under it.
Your storm collar is cemented to the cap material, should be up an inch or so and not cemented. The cap should have a raised 1" lip integral to it- the pipe passes through. The collar can be caulked to the pipe, not both as the expand/contract differently. (You want the seal at pipe/collar to direct water out away from pipe onto collar).
It appears you have at least one fastener in the cap flashing, make sure each corner has one, not to blow off in a pressure difference high wind.The diagonal folds are still present in the metal, it doesn't appear distorted to pond water; http://inspectapedia.com/chimneys/Wood_Chimney_Chase.htm
Wrong roof boot, it should have had a flange that gets screwed down to the metal with metal roofing screws with silicone under the flange.
There also is no rain ring.
No cricket above the roof on the high side of the chimmney to devert water away from the chimmney.
Why is the J moulding cut where it meets the roof?
I run all the solid flashing and step flashing, then add a band of 1 X 4 vinyl lumber at the bottom of the chimney. On top of that I install Z moulding then install the J moulding and siding.
What this does is cover up and protect the areas most likly to leak.
Is this something someone added on after the house was built?
I've had to repair a few of these and 90% of the time it leaks because of the flashing done wrong in the corners and at the bottom of the chimmney.
I've removed the siding and a few shingles and could look right down inside the attic or at least at bare sheathing.
I am a newbie so forgive me but is there a diagram or picture that would illustrate the flashing design you recommend? I think I am missing something fundamental. The rain rolls down the roof hits the chase flashing and then diverts to... where? It seems to me that it is now under the shingles and on the roof decking. The cricket seems really, really important but even on the side flashing, how do you avoid water on the decking if the shingles run right up to the chase flashing. The J channel, if I understand, just diverts runoff running vertically down the siding.
This is all original design and construction. The house was built 9 years ago. I am the second owner. I realize this is "out of warranty" but I called the builder anyway based on the comments here, and he responded that it is not his problem. He said the home inspector should have caught it if there was a problem. From what I hear here, this is not "wear and tear" but rather poor design.
Poor design/construction indeed and from the builder's response it sounds like he knows it...
Follow WOW's advice and try to narrow the leak source down. That will help to determine exactly what remedy you'll NEED to do. Though I do recommend making plans to fix all the items Joecaption noted...
Run the hose on the shingles above the chimney, do not wet the sides or top of the chimney.
If it leaks you know you have an issue where the roofing ties into the chimney.
Let it dry out....
run the hose on the chimney cap and check for leakage.
It is best to have someone in the attic, hopefully its not vaulted ceiling, and as you run water at each location you have a set of eyes watching in the attic.
Yeah... That is a hack job in its finest.. Hopefully you've caught it soon enough. Caulking will not fix that one. Call up Mike Holmes, he'll fix ya right up. :yes:
Gary got it right,you need to pull some siding,probably will be something simple like no paper over the step or corner flashing not proper or a piece of step slide down
you can get a zip tool,but thats Monogram and it will fight being unlocked a bit:thumbsup:
Gunadi,
The Chase Cover on the top is definitely causing some of the problems. The cover is sagging and collecting water and snow (depending on where you live). Once the seal cracks around the storm collar (where the rust is beginning to show) and also above where the storm collar appears to be broken. There is nothing to prevent the water from going down through the chase and into your attic. The chase cover should have a minimum of a 2" high collar around the pipe to prevent water intrusion, along with a tight fitting storm collar. The chase should be made from a material that resits corrosion to prevent rusting and holes.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
