Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 10-31-2009, 12:06 PM   #1
Determining Roof Leak after Repairs
Had a roof leak on roof less than one year old. Roofer made repairs but said to wait for more rain to make sure leak fixed before painting.
I asked best way to tell if really fixed. He suggested spraying a 50/50 mixture of bleach and water on the stain. I sprayed the stain two times but it does not completely go away.
Thought about spraying some Kilz to cover the stain but thought this might tend to seal the area and make leak detection more difficult.
Any other suggestions?
wallace1 is offline   Reply With Quote
Old 10-31-2009, 06:50 PM   #2
The only way to get rid of the stain now is to replace the shingles. It makes me wonder what type of contractor you had work on your house if he said to mix bleach and water to find a leak. How often does it rain bleach? In my mind, that does not make sense.
BamBamm5144 is offline   Reply With Quote
Old 10-31-2009, 07:45 PM   #3
If I am reading the post correctly, I think the roofer was suggesting hitting the damaged area on the inside with the bleach and water not the roof to see if still leaking. Kilz or any white pigmented shellac should cover the stain that the leak caused and I doubt it will hinder any new leak from showing up for too long.
meboatermike is offline   Reply With Quote
Old 10-31-2009, 11:14 PM   #4
Replace the drywall
johnk is offline   Reply With Quote
Old 11-01-2009, 12:32 PM   #5
meboatermike, you are correct.
Thanks.
Strange Winter Roof Leak Dragon Roofing 16 10-09-2009 07:06 PM
Flat roof questions, advice, ballpark estimate JerryH Roofing 18 11-07-2008 05:08 PM
Cathedral Ceiling - mystery roof leak kamadus Roofing 4 05-06-2008 02:18 PM
