Degraded Plywood - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-17-2010, 08:39 PM   #1
Degraded plywood
I signed a contract with a roofer. They have started the job Today but I can see in all the plywood sheets the following stamp: "DEGRADE ALL OTHER MARKS VOID". I think that means they are using second or even third quality material, am I right? Should I immediately ask this company to change these plywood pieces for first quality ones?
dleon is offline   Reply With Quote
Old 08-17-2010, 09:06 PM   #2
Doing This Way Too Long
Rewards Points: 532
I've never seen that label but I would assume they are seconds. (called blows here).
Should they be using it? Depends on what they are doing? Are they re-sheeting over existing skip sheeting? If so I don't see an issue with it. The skip sheeting still remains your main decking. The plywood just gives a solid surface to nail an asphalt roof to. Standard here is 7/16" osb and I would consider even 1/2" plywood seconds to be superior to osb.
Now if it is just going over trusses and is your primary roofdeck then, yes, I would have some concerns about it.
OldNBroken is offline   Reply With Quote
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 06:47 AM
How to install 3/8 underlayment plywood? dangdang Flooring 8 09-26-2009 04:21 PM
Tiling - Gap in plywood (sub)floor mcg Remodeling 5 01-15-2009 04:21 PM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
