Debris Blowing Into My Attic From Vents - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-11-2011, 09:07 PM   #1
Debris blowing into my attic from vents
Hello,
A couple of years ago I had a metal roof put on my house. Ever since, I've been getting a ton of debris in my attic! Small leave or "helicopter seeds" galore!
Is this normal? Is there a way to stop it? Any suggestions?
Thanks in advance for any information at all!
Cindyloo670 is offline   Reply With Quote
Old 10-12-2011, 08:58 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
It will be normal if they did not screen or put some cobra vent on ridge vent prior to their cap.
You should be able to put some screen up there from inside the attic.
Old 10-12-2011, 02:18 PM   #3
In other words, they neglected to put something on the vent?
I'm going to call them and make them come back. Will it be hard for them to fix it now?
I can't screen it from the inside. I was going to do that but someone pointed out that the debris would collected against the screen and eventually block the airflow.
Thank you for your help!
Old 10-12-2011, 03:23 PM   #4
Rewards Points: 252
Typically there is a foam material that fits inbetween the ribs to block snow and debris.
shazapple is offline   Reply With Quote
Old 10-12-2011, 03:56 PM   #5
Foam? So there could be something called Cobra vent, screen, or foam? If there were foam, how could the ventilation occur properly?
Old 10-12-2011, 08:02 PM   #6
Rewards Points: 252
When I say foam I am referring to a Cobra vent type material. It should be easy for them to remove the ridge cap and add it.
Old 10-12-2011, 08:13 PM   #7
Oh ok, thank you so much for the help!
Attic baffles but no overhang or soffit vents. Ptron Roofing/Siding 12 08-04-2010 11:51 AM
Attic ventilation without soffit vents jayman9782 Building & Construction 0 06-14-2010 09:26 PM
How to keep attic pipes from freezing in winter with gable vents ErikKratz HVAC 7 07-11-2008 10:32 PM
Attic venting - Ridge vents or fans? jebmke Roofing/Siding 16 07-03-2008 12:03 PM
Leaking attic gable vents MoMo Roofing/Siding 2 04-02-2005 10:00 PM
