Daylight Visible In Attic, Under Stove Hood Vent! - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-21-2014, 11:44 PM   #1
Rewards Points: 682
Daylight visible in attic, under stove hood vent!
I've noticed daylight in our very shallow attic. It comes from around the vent for the stove hood. This doesn't feel right. Is there any venting that is supposed to let in daylight from the roof? Someone ran a flex duct from the hood into the attic, I wonder if the duct somehow got detached from the roof vent?
I've been on the roof, and the vent looks normal from there. When I run the stove hood air is pushed out the vent.
darsunt is offline   Reply With Quote
Old 04-22-2014, 01:05 AM   #2
iminaquagmire's Avatar
Rewards Points: 338
You should not see daylight from a duct exit. It should be continuous to the exterior of the roof. I wonder if maybe the duct was run to a roof vent without a proper exhaust vent installed. Also, flex duct should not be used on a hood exhaust. The ridges collect grease which can be a fire hazard.
iminaquagmire is offline   Reply With Quote
The Following User Says Thank You to iminaquagmire For This Useful Post:
Windows on Wash (04-22-2014)
Old 04-22-2014, 01:55 AM   #3
CRCA Roofing Contractor
RoofingTrades's Avatar
Flex duct not meant for hood ranges. And you should not see any daylight at all.
RoofingTrades is offline   Reply With Quote
Old 04-22-2014, 06:24 AM   #4
Rewards Points: 14,306
Got a picture so we can see what your seeing?
Roofers Advice (04-26-2014)
Old 05-10-2014, 08:27 PM   #5
Rewards Points: 682
Here is the picture.
The light is in the center of the pic, over the pipe and under the beam. You can vaguely see the flexible vent pipe, and the light around it. It's about 25' down the center of the attic. Quite bright.
Oddly, when the hood fan is blowing there is air being pushed out of the vent on the roof. So I am not quite sure what is going on.
The flex line was installed when they put in the torched roof 3 or 4 years ago.
Mark
Old 05-10-2014, 08:29 PM   #6
Rewards Points: 682
Here it is
Old 05-10-2014, 10:17 PM   #7
Metal Roofing
Rewards Points: 600
Your probably seeing light coming in from the 7" t-top, the ducting is run short or its not large enough to fill the 7" opening of the 7" t-top. Light is coming in around the duct because its not a good fit or came loose.
Here is what you have:
http://www.bestmaterials.com/detail.aspx?ID=20151
AndyWRS is offline   Reply With Quote
Old 05-12-2014, 05:48 AM   #8
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Well, despite the others comments, the rule of thumb is this.
Seeing the sky is bad. Seeing reflected light, but not the sky is usually fine. Pix from above would be nice.
Are you seeing light. or sky? Big difference. Some hood setups use a collar, then a pipe collar cap which is separate and reflected light is not unusual.
tinner666 is offline   Reply With Quote
New Roof marknok Roofing/Siding 4 08-06-2011 11:41 AM
Can I install a hood vent pipe with a 90 turn? Stephen S. Appliances 9 03-10-2010 12:52 PM
GE Monogram Vent Hood arubatan Appliances 6 02-04-2008 10:32 AM
is an attic vent required for cedar shingle roof? walenta Building & Construction 2 10-25-2007 10:31 AM
can I 'patch in' a bathroom vent into my kitchen's stove hood vent? joeyboy HVAC 2 09-10-2007 12:36 PM
