Damp Roof Trusses - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 01-06-2009, 03:07 PM   #1
Damp Roof Trusses
To my horror I discovered a lot of condensation in my attic last weekend, the timber in the roof trusses seem to be soakin up moisture from condensation on the back of the roof felt. I have recently installed a gas fire with a strong output and uPvc windows which are both probably adding to the problem. I plan to add extra ventilation but need advice - at present only have soffit vents - these I need to check as I got them covered a year ago with plastic maintenance-free ones by a contractor. As my house has gable walls to front and back I plan to add exhaust vents, one on each end at high level but wonder if I should add smaller vents at floor level of attic or just ensure the vents in soffits are ok. Also once I have all the timber dried out, can I treat it with some type of preservative.
diypaddy is offline   Reply With Quote
Old 01-06-2009, 03:46 PM   #2
old timer
Hard to give a detailed answer without more info.
Try this link for attic ventilation info.
http://roofingcontractorreview.com/R...ntilation.html
Definately check the soffits for blockage. Continuous soffit vents around the perimeter of the house are best.
dmc@RCR is offline   Reply With Quote
Old 01-06-2009, 04:07 PM   #3
attic condensation
Thanks old timer only problem is I don't have any ridge vents at all - so if I check my soffit vents and add exhaust vents on gable ends will I likely get a flow of air through the attic
Old 01-06-2009, 04:19 PM   #4
Remodeling Specialist
You must have gable end vents or ridge vents to exhaust the air containing the moisture. If you only have soffit vents then you have intake , so to speak and no exhaust.
Baron is offline   Reply With Quote
Old 01-06-2009, 04:43 PM   #5
damp roof trusses
I live in a large housing estate and half of the houses are just like mine - the ridge tiles are all cemented down with no gaps or vents ( the roof felt is continuous inside the attic ) and there are no openings / vents on either gable end
Old 01-06-2009, 06:32 PM   #6
old timer
Soffit vents alone will act as both intake and exhaust. But will not be as efficient as soffit vents with gable vents and or ridge vents.
Yes
Flat roof questions, advice, ballpark estimate JerryH Roofing/Siding 18 11-07-2008 04:08 PM
Setting trusses for a Hip roof? TonyGG Building & Construction 13 09-13-2008 08:47 AM
Attic trusses and proper roof pitch Rob63 Carpentry 1 07-28-2008 03:38 AM
