Damp Problem/leak - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-29-2009, 11:52 AM   #1
Damp problem/leak
Hi
Whilst clearing out our loft I have noticed a damp patch at the apex of one of the roof trusses. It looks as if there could be a minor leak in the roofing felt but I can't see any gaps through it when I look with a torch.
Can anyone hazard a guess at the likely problem ? For context the roof construction is trussed rafters - early 1980's construction. I've attached a few photos of it.
My best guess was that a ridge tile might be loose - however from outside nothing seems to be seriously out of place.
I'm concerned of possible structural problems with the roof if I don't get this sorted quickly.
Any ideas about what might be wrong or the best first step in finding out would be greatly appreciated
John
Damp problem/leak-dscn0481.jpg   Damp problem/leak-dscn0483.jpg
Bungle is offline   Reply With Quote
Old 11-29-2009, 04:48 PM   #2
Rewards Points: 582
The trussed rafter may have penetrated the felt, and the ridge tile above could have moved slighty away from the mortar joint leaving enough of a crack for water to come in.
stuart45 is offline   Reply With Quote
Damp walls lara1234 Building & Construction 6 10-28-2009 04:10 AM
Damp walls - should I use foil bubble wrap!? thenap80 Building & Construction 7 12-19-2008 12:40 AM
Did the bush cause the damp? atomicpig General DIY Discussions 9 02-13-2007 08:00 PM
