Damp Patch Chimney Breast - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-14-2008, 03:05 AM   #1
I currently have a damp patch in our bedroom on the side of the chimney breast. It seems to have started near the back wall but is visible on the ceiling and back wall.
I have had two roofers look at the flashings around the chimney, one wanted to replace the whole lot and the other quoted for pulling the flashings away re pointing behind and around them.
Having been up looking at the flashings previously i opted for the repair as i knew they weren't in as bad condition as the first roofer said.
I'm not 100% sure but i think water may still be coming in but obviously it will take time for the damp patch too dry out.
Our Chimney is on a gable end so flush with the wall. One thing the first roofer said is that when water runs down the chimney wall (on the gable end) it could be getting behind the fascia board. Now obviously the chimney has the back gutter flashing and the two sides but on a chimney like this is it supposed to have a flashing strip accross the front to direct water running down the wall into the gutter ?
Our gable end was rebuilt a couple of years ago by the previous owners and I'm wondering if this has been missed off ?
If it makes it any clearer i can post photos.
Mark
Mark_84 is offline   Reply With Quote
Old 10-14-2008, 06:13 PM   #2
Residential Roofer
Slyfox's Avatar
Sorry, I would like to see a pic before commenting being i'm somewhat unsure of the situation as you have explained it.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 10-15-2008, 04:41 PM   #3
home improvement guru
aaron.klimchuk's Avatar
+1, pics will definitely help also check out http://www.fixthehome.com/cat/roofing/topics/flashings/ if you want some more opinions.
Last edited by AtlanticWBConst.; 10-25-2008 at 08:04 AM. Reason: Site Rules Violation: Business Web link Removed
aaron.klimchuk is offline   Reply With Quote
Old 10-16-2008, 04:52 PM   #4
Doing This Way Too Long
Rewards Points: 532
yes, pictures would make this pretty easy I believe.
OldNBroken is offline   Reply With Quote
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 07:16 AM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 12:23 PM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 04:12 PM
Knocking into the chimney breast? darrenbooy Building & Construction 1 10-30-2006 10:13 AM
