Cutting Shingles On The Eve - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 04-02-2007, 07:51 PM   #1
Cutting shingles on the eve
So I'm reshingling the roof on our shed. The shingles are hanging off the eves by a few inches. Whats the best way to cut these for a nice straight line? I bought some hook blades, but that process seems tougher than it should be. Can you use a circular saw? Someone told me that the saw would melt the tar and I'd end up with a mess. I'm only doing a total of maybe 20 feet here.
Thanks!
xray328 is offline   Reply With Quote
Old 04-03-2007, 11:46 AM   #2
cut as you go is the best way.pop a chaulk line and start at the top and come down.I usually give about a 1/2" over hang.
use your hook blades and cut one shingle at a time it goes really fast once you get going.
roofwiz74 is offline   Reply With Quote
Old 04-03-2007, 07:41 PM   #3
The blades getting stuck where the upper and lower half of the shingle overlap.
Old 04-03-2007, 07:53 PM   #4
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
X,
In that case, cut them straight - one layer at a time. (top overlap layer...and then, the bottom layer.)
Good Luck...
- Build Well -
Old 04-03-2007, 08:37 PM   #5
oops my bad.
Old 04-03-2007, 08:38 PM   #6
pick up on the shingle when you cut it.
Old 04-03-2007, 09:12 PM   #7
And keep yout 'nose-pickers' away from the blade....while slicing....
- Build Well -
Old 04-03-2007, 11:24 PM   #8
Commercial Roofing
AaronB's Avatar
Did you get the cheese grater yet?
www.roseroofing.net/ Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 04-04-2007, 06:02 PM   #9
The problem I'm having isn't where the individual shingles overlap. These are 30 year shingles, so the top black part of the shingle is a separate piece that overlaps the exposed shingle. The two are glued together.
Old 04-04-2007, 07:21 PM   #10
Commercial Roofing
AaronB's Avatar
yeah, those are tough to cut. watch out for the cheese grater effect.
Old 04-04-2007, 09:15 PM   #11
Hey, I just noticed you're in Lockport. I'm over in Shorewood. Wanna make some quick $? It's just an 8x10 shed.
Old 04-14-2007, 05:58 PM   #12
I've about given up in cutting these after scraping my knuckles more times than I care to count. Seriously Aaron, are you interested in taking over this job?
Old 04-14-2007, 06:23 PM   #13
Either use some big bull nose tin snips to carefully scissor your way through them or place a 3 foot long 1" x 4" under the shingle overhang to gain some stability while cutting them off with a knife.
The tin snips with a straight edge for a guide will probably work out better.
I'm talking about a large pair with about a 3" depth on each cut. but don't cut all the way to the 3" point, just cut about half way through to keep a straight line edge going.
Ed
Ed the Roofer is offline   Reply With Quote
Old 04-14-2007, 08:33 PM   #14
Ok, I'll give it a try.
One more thing....
Since I couldn't cut off the overhang that been there for a week, the shingle is now bent at about a 70 degree angle at the edge of the roof from the weight of the excess shingle. Is there a way to get it back straight? It's been pretty cold so the shingle is stiff.
I was thinking about using a heat gun to soften it up?
Old 04-15-2007, 12:08 AM   #15
If you cut it back so that there is onlu about a 1" overhang, then the most severely curled portion should be eliminated.
Don't try to heat them up. because they will either gum up the cutting process or loosen the asphalt embedment and possibly dislodge the granular protection.
It's just a shed, so just get it to look symetrical. You are the onlu one who will be critiquing it for the rest of it's life. No one else will ever notice, unless you do a complete hack job on the edge cutting, but the tin snips will do the job even better now that the temperatures are still a bit on the chilly side.
It's supposed to hit around 58* to 61* on Monday, so get them snips and get to cutting, but take your time and be neat and safe.
Ed
GAF Roof... the best EdPDX Roofing/Siding 73 09-12-2011 05:53 AM
Shingles per bundle redline Roofing/Siding 11 09-11-2011 10:41 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Masonry Asbestos Shingles, how do I know? ourzoo Building & Construction 8 08-27-2007 08:57 AM
bending shingles farrington135 Roofing/Siding 2 06-09-2007 10:40 AM
