Cutting My 2 X 8 Fascia Boards - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-04-2008, 08:47 PM   #1
Rewards Points: 81
Cutting my 2 x 8 fascia boards
I'm about ready to cut my 2 x 8's so i can put up my new fascia. From what I've read on compound miter saws and sliding compound miter saws they recommend going with a 10 inch blace. They say a 12 inch blade wobbles more and I'll lose accuracy. My local hardward stores only have a 12 inch blade for rent (a Ridgid). For the job I'm doing will it make that much difference if I use a 12 inch blade? If it does, I'll go out and purchase a 10 inch. Just wanted to some input on this, please. Thanks
joefromcal is offline   Reply With Quote
Old 09-04-2008, 08:59 PM   #2
Doing This Way Too Long
Rewards Points: 532
Dunno who told you that, but it's definitely not true. All depends on the brand of saw I guess. I have a makita 12" sliding compound, best saw made I think.
OldNBroken is offline   Reply With Quote
Old 09-05-2008, 12:49 AM   #3
Custom Cabinet Maker
Joe, remember that fascia is running on an angle and the plumb cuts will be longer than that nominal 8" so 12 is a much better saw for the job. Plus 12 is just as accurate as smaller.
skymaster is offline   Reply With Quote
Old 09-05-2008, 06:30 AM   #4
the Musigician
DangerMouse's Avatar
i agree with OldNBroken, the hdwr store probably would rather SELL you a 10" saw than RENT you a 12. and besides, fascia is not fine furniture, where precision is important. a fascia can be a 'hair' off and who'll notice?
DM
Old 09-09-2008, 09:08 AM   #5
It will only wobble on a cheap saw or if not tightened correctly.
You can butt the corners and fill any slight void with a good polyurethane paintable caulk such as Vulkem and make the job much easier on yourself with similar results. Wait 2 days to paint the caulk after it cures and hardens.
Ed
Ed the Roofer is offline   Reply With Quote
Where do I nail Aluminum Fascia? irlizard Roofing/Siding 10 09-07-2016 12:21 PM
replacing fascia board joefromcal Roofing/Siding 12 08-18-2008 06:33 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
hardwood flooring boards matjone Flooring 4 02-01-2008 05:35 PM
Are fascia boards rough carpentry? Paul58 Building & Construction 10 04-19-2006 10:18 PM
