Cutting Metal Gutter In Place On 2nd Story - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-13-2014, 11:00 AM   #1
Rewards Points: 12
cutting metal gutter in place on 2nd story
I am building up the outer surface of a chimney by approximately 1-3/4". The chimney intersects the gutters on the 2nd story roof line, so the gutters on either side of the chimney terminate with end cap when they get to the chimney. To build out the surface, the gutters will need to be cut back by the thickness I am adding to the chimney (1-3/4"). So here is the question.
How to cut off 1-3/4" of the gutters while the gutters are in place without mangling them and damaging everything around it?
thanks - Tim
hardmat is offline   Reply With Quote
Old 08-13-2014, 03:28 PM   #2
Metal Roofing
Rewards Points: 600
Tin snips
AndyWRS is offline   Reply With Quote
Old 08-13-2014, 09:53 PM   #3
Lightfoot's Avatar
Rewards Points: 272
Dremel with a cutoff wheel works wonders. Also might try an oscillating multi-tool with metal cutting blade. Good luck!
Flashlight: A cylindrical container used to store dead batteries
Lightfoot is offline   Reply With Quote
Old 08-13-2014, 09:53 PM   #4
Rewards Points: 610
+1 on snips, and it'll be easier if you loosen a few spikes/hangers nearby first.
PatChap is offline   Reply With Quote
Old 08-14-2014, 11:58 AM   #5
Rewards Points: 12
Lightfoot - I'm thinking the same way you are re: oscillating tool. I have Fein Multimaster and yesterday I bought a 2" diameter metal cutting blade so I can work from inside or outside the gutter to make the cut. I am thinking this will result in a cut a lot less ragged and will be safer/easier to handle while on the ladder. I also like the idea of loosening a few spikes to be able to pull the gutter away from the fascia board a little. This will aid in cutting and reduce the amount of "through cut" into the board behind the gutter.
Since I only need about 2" of length cut off, I think I'll cut off the last 6" from the end cap (to give me room to work with the siding etc), and then maybe I will luck out and be able to just place the old end cap butted up to the new siding surface and overlap the 2" of extra length into the remainder of the gutter in place and seal it. May have to do some trimming to make that work or I might have to cut off that overlap and butt joint the cut edges and epoxy them together???? We will see.
Any ideas on how to make this work better, I'm all ears!
Old 08-14-2014, 09:08 PM   #6
Metal Roofing
Rewards Points: 600
I think what your proposing would work, normally I wouldn't recommend a MM but if you have one may as well use it. Any time I can use mine I will, they are not exactly cheap and the more I use it the more can justify its cost. You can overlap the gutter, but I think the best idea is to just replace the end cap with a new one...they are cheap.
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 02:33 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 06:59 PM
Best place to buy sheet metal and lumber? jk333 Building & Construction 6 02-25-2009 10:22 AM
Cutting off 3" of laminate counter top in place 4just1don Building & Construction 3 09-27-2008 10:33 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
