Cutting Corrugated Sunroof - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 08-31-2012, 09:12 PM   #1
Solutions (handyman)
Rewards Points: 362
Cutting corrugated sunroof
A client has a corrugated semi-clear plastic covering over their porch area & the roof is angled from an over hang of about three feet at the peak to zero where the roof meets the walls. The verticle sheets (on the roof) at right angles but the overhang area has been trimmed to accomadate the angle. I need to replace some of the material but, as it is about fifteen years old, I am concerned about cutting the plastic without it cracking, splitting or chipping. What is the best method to cut this material ... especially considering its age?
Thanks.
Mark Harvey is offline   Reply With Quote
Old 08-31-2012, 09:16 PM   #2
Rewards Points: 13,300
Plywood blade on a ciruler saw on backwards.
But get it in writing your not resonsable if it cracks because more then likly it will.
Old 08-31-2012, 11:46 PM   #3
an angle grinder with a thin cutoff wheel
The Following User Says Thank You to DannyT For This Useful Post:
OldNBroken (09-01-2012)
Paver patio/wall corrugated drain location BrandonC_1972 Landscaping & Lawn Care 0 07-05-2012 12:31 AM
corrugated metal or standing seam for irregular roof? nicole21 Roofing/Siding 6 09-08-2010 03:58 PM
Corrugated Fiberglass Roof theriver Roofing/Siding 1 09-16-2008 10:37 PM
Cutting Board DaveSteel Carpentry 1 02-21-2008 10:38 AM
Corrugated over Corrugated picman98 Roofing/Siding 1 07-01-2007 01:36 PM
