Cutting Corners Of Shingles Off... Adhesive - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-29-2007, 10:29 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
Cutting corners of shingles off... adhesive
I'm roofing a bay window. For the hip shingles, I want to cut the bottom corners off so that it ties the two sides of the roof in better. That also means that I'm cutting off most of the adhesive that is there. Is this not advisable? Can I just use a roof sealant to glue them down or will they naturally glue down on their own?
TIA
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 09-29-2007, 05:14 PM   #2
I do not know why you intend on clipping the bottom exposed corners of the hip cap shingles.
Typically, on a light colored roof shingle, the top corners are cut "dog ear" style so the darker top portion of the shingle does not reveal itself and stand out.
You are intending on nailing them in place, aren't you? Then why be concerned about the lack of 1" or 2" of additional adhesive?
If you are, then you can apply a small quarter sized dap of plastic roofing cement under the tabs for your concerns.
Ed
Ed the Roofer is offline   Reply With Quote
Old 09-29-2007, 05:53 PM   #3
I have gas!
I did end up cutting the corners and putting a dab of adhesive in the on each corner. I think it came out pretty good.
Cutting corners of shingles off... adhesive-bayroof.jpg   Cutting corners of shingles off... adhesive-baywin.jpg
Curved corners where drywall meets? SouthGAreno Remodeling 12 01-17-2013 03:10 PM
cutting shingles to install gutters Chicago Bill General DIY Discussions 2 02-27-2009 05:42 AM
Does GAF still make 40yr shingles? Marlin Roofing/Siding 8 10-07-2007 12:49 AM
Solar Shingles? CuCullin Roofing/Siding 2 09-21-2007 08:11 AM
Cutting shingles on the eve xray328 Roofing/Siding 16 04-15-2007 04:54 AM
