Cutting Architectural Shingles. - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-01-2012, 10:39 AM   #1
cutting architectural shingles.
What is the easiest way to cut them for a hip roof ??
alpaca is offline   Reply With Quote
Old 02-01-2012, 12:58 PM   #2
firehawkmph's Avatar
Rewards Points: 1,884
You can use a utility knife with roofing blades, along with a straight edge. If you are cutting them before nailing, cut them from the backside. A small scrap of plywood makes a nice cutting surface.
http://www.lowes.com/pd_293929-355-1...ductId=3184867
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 02-01-2012, 01:27 PM   #3
Rewards Points: 2,212
Around here usually we get 3 tab shingles in the same color and cut them for the hips/ridges.
mae-ling is offline   Reply With Quote
Old 02-01-2012, 06:10 PM   #4
Alpaca,
maybe I misunderstood your question. Are you asking how to cut them up for ridge caps? Most of the manufacturers offer special ridge caps to match up with their architectural shingles. They're layered up so they blend in and look like the rest of the shingles.
Mike Hawkins
Old 02-01-2012, 09:54 PM   #5
RFN-4A-LVN
Roofmaster417's Avatar
Mike Hawkins
You posted right Firehawk.The post was for cutting Arch's.
I cut mine as they are installed.Once they are installed angle the knife/blade slightly.Remember you are wanting to slice the shingle.,No need to dig into it like your cutting a roast.
Roofmaster417 is offline   Reply With Quote
The Following User Says Thank You to Roofmaster417 For This Useful Post:
firehawkmph (02-03-2012)
Old 02-01-2012, 10:29 PM   #6
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Some people run them all the way up, pop a line, and cut them with a circular saw.
titanoman is offline   Reply With Quote
Old 02-02-2012, 07:39 AM   #7
A hook blade.
jmiller is offline   Reply With Quote
Old 02-02-2012, 07:49 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
really??????
I've never seen that one.
More info please????
tcleve4911 is offline   Reply With Quote
Old 02-02-2012, 07:53 AM   #9
I don't care if you do it, but don't use my saw!
The Following User Says Thank You to jmiller For This Useful Post:
Old 02-02-2012, 08:09 AM   #10
Disabled wood vet
titanoman's Avatar
Originally Posted by tcleve4911
really??????
I'm just saying I've seen people do that. That's all.
Old 02-02-2012, 12:44 PM   #11
Seen that done for gable ends, measure out 1/2" or whatever at top and bottom, snap line and cut. Never done it myself.
What I usually do is shingle the entire side letting the shingles run long over the hip, snap a line, then cut with a hook blade.
Old 02-02-2012, 09:13 PM   #12
RFN-4A-LVN
When I install GrandManors or the Berkshire in the winter months I use an angle grinder.Actually I use one with every super heavyweight shingle.
I have seen skil saws used on hip roofs.They buy a multi tooth fine blade and turn it around backwards.Pretty much like cutting soffit or siding.
Architectural shingles to buy vs. regular vkerns Roofing/Siding 24 08-04-2016 04:31 PM
Re-roofing Architectural Shingles over Architectural Shingles NoDIY4Me Roofing/Siding 11 04-08-2014 07:50 PM
cutting architectural shingles to create stair step wombosi Building & Construction 3 10-13-2011 08:27 PM
Weight vs. durability of architectural shingles JoeT Roofing/Siding 10 06-29-2009 06:50 AM
reg. or Architectural shingles? fricandfrac Building & Construction 6 04-02-2009 04:47 PM
