Cut-Valley Question - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-13-2009, 10:22 AM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,362
Cut-Valley question
For a cut valley, does it make any difference which side is cut, main roof or addition roof?
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 11-13-2009, 01:25 PM   #2
Yes it makes a difference. If one side is steeper, that is the side you want to cut. If both sides are the same pitch, you want to cut the side that will have more water running down it, most likely the main part of the roof.
BamBamm5144 is offline   Reply With Quote
Old 11-14-2009, 07:43 AM   #3
You also want to take into account which direction most of your weater patterns come from.
bronco2 is offline   Reply With Quote
Need input on this open valley technique jogr Roofing/Siding 12 11-01-2011 06:49 AM
Intersecting "W" valley at different angles question HanksLBZ Roofing/Siding 3 10-07-2008 09:22 AM
Sagging Valley in Victorian Toronto...sisterning HELP? sbellerby Roofing/Siding 5 08-01-2008 03:54 PM
Open valley flashing question steve1234 Roofing/Siding 2 10-01-2007 12:19 PM
