Cupola For Venting Attic - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-26-2012, 10:09 AM   #1
Cupola for venting attic
Any reason a cupola properly sized would not serve as adequate ventilation on a hip roof? Roof is square and come to a peak like a pyramid and there would be adequate soffit vents. thanks
Mike in Arkansas is offline   Reply With Quote
Old 07-27-2012, 06:08 PM   #2
Rewards Points: 16
You could just install a few roof vents close to the peak but, if you really wanted to build one of those i dont see why it wouldnt work, it would do its purpose for sure, just extra unneeded work if your needs was just ventilation
edit: that one cupola probably isnt enough ventilation by the way, i would go with 3-4 roof vents spread out
if you didnt want to install more soffit vents (thats if u didnt have many) a simple way to help that out is just install couple more vents
vandel777 is offline   Reply With Quote
Old 07-29-2012, 12:37 AM   #3
Registered User
Rewards Points: 526
On your full hip (4 square) roof a cupola would be perfect, just size it correctly, as you said.
Gary
Insulating your attic Bob Mariani How To Guides 5 07-07-2013 08:49 PM
Attic - Replacing electrical - Positioning, how many boxes, checking understandings darlingm Electrical 12 12-04-2011 11:17 PM
Help with complicated insulation project in attic OhmZoned Insulation 12 11-19-2011 08:49 AM
Attic project - Would like opinions whataboutj Insulation 6 06-29-2011 03:07 PM
Ventilating attic with two roofs senorbungle Building & Construction 2 01-09-2011 04:17 PM
