Cricket In Valley. Will This Work? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 07-22-2010, 08:41 PM   #1
Cricket in Valley. Will this work?
I have a low spot where the different angles of the roof come together. I am thinking about building a cricket in the valley to displace the water. Take a look at the pic and tell me do you think it will work? Thanks in advance.
Cricket in Valley.  Will this work?-bobby-singhinspection.pdf-adobe-reader.jpg
blahblah82 is offline   Reply With Quote
Old 07-23-2010, 07:44 AM   #2
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
That's a roofer's nightmare. You need to trim the cornice back up off of the roof some. I've drawn how I would build the cricket and then I'd go slap an architect.
seeyou is offline   Reply With Quote
The Following 2 Users Say Thank You to seeyou For This Useful Post:
MJW (07-23-2010), Tom Struble (07-25-2010)
Old 07-23-2010, 07:55 AM   #3
Doing This Way Too Long
Rewards Points: 532
sorry, no. all you are doing is decreasing the slope on an already disastrous detail.
OldNBroken is offline   Reply With Quote
Old 07-23-2010, 09:57 AM   #4
Hmmmmm
Well seeyou says i can do it but oldnbroken says i can not. Any other suggestions? Thanks again in advance.
Old 07-23-2010, 10:32 AM   #5
kwikfishron's Avatar
Rewards Points: 344
Is that new construction, an addition?
GC, framer or someone should have caught that way before roofing.
kwikfishron is online now   Reply With Quote
Old 07-23-2010, 11:19 AM   #6
Graphics Specialist
kredman's Avatar
can we see a wider shot of the roof system?
kredman is offline   Reply With Quote
Old 07-23-2010, 12:54 PM   #7
3 Years Old
House is not a new construction or doesn't have an addition. House is abut 3 years old. I am buying it and inspector caught the problem. I have untill Monday to get out of Contract
Old 07-23-2010, 04:42 PM   #8
I agree with Seeyou.
Building a proper cricket, or proper flashing would help reduce the problem.
Where do you live? Do you also get snow?
Paragon221 is offline   Reply With Quote
Old 07-23-2010, 04:51 PM   #9
I live in south Louisiana where we barley get snow. Does anyone think this can't be done?
Old 07-23-2010, 06:02 PM   #10
Rewards Points: 344
If you like and want the house don’t let this be a deal breaker.
It can be dealt with. Some kind of cricket (water diverter) has to happen. Whether it’s framed with wood and roofed or done in metal, diverting the water is defiantly doable.
The Following User Says Thank You to kwikfishron For This Useful Post:
seeyou (07-24-2010)
Old 07-23-2010, 10:00 PM   #11
Wow. Thats what I wanted to hear. Thanks for the advice everyone.
Old 07-24-2010, 11:12 PM   #12
Water Test
I also got on the roof and took a gallon of water with me and slow pouered into the valley from different angles and noticed that the water did not pond at all. What can cause the water to pond if it would at all?
Old 07-26-2010, 03:25 PM   #13
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
I can do those easily, but I can never explain the process.
I end up removing the bottom shingle, or two on the left side, and cutting the trim and rake back. Then, I use metal to terminate the valley so it squirts the watewr on out of there without going under anything.
Similar to this one. Here're the before and after photos of one I did.
Cricket in Valley.  Will this work?-100_1793.jpg   Cricket in Valley.  Will this work?-100_1887.jpg   Cricket in Valley.  Will this work?-100_1886.jpg
tinner666 is offline   Reply With Quote
Old 07-26-2010, 03:26 PM   #14
Pro Slate Roofer
tinner666's Avatar
My valley would wrap around and over that corner by time I was finished.
Old 07-26-2010, 04:44 PM   #15
Great Pics. Thanks for the post!
Issues w/ Old Work Box mkrawitz Electrical 5 04-19-2010 11:53 AM
Need help with permit/city got a Stop Work Order. amdspitfire General DIY Discussions 39 02-07-2008 02:45 PM
Am I being overcharged for general construction work? baloney12 Building & Construction 2 07-11-2007 06:09 PM
Electrical service too near valley of roof? adamselene Roofing/Siding 3 05-11-2007 07:56 AM
