Cricket For Sidewall Chimney? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 02-24-2009, 01:17 PM   #1
Question
Cricket for sidewall chimney?
Hello, I have side wall chimney that cuts through the soffit. Actually only about 18 inches of it cuts through, see the attached pic, above the arrow. My siding guy is out there now and he's asking me how I am going to divert the water away from the chimney.....ugh, don't know!
It's a 4/12 pitch on the roof. Like I said b4 about 18 inches of chimney cuts into the roof. We were looking at it last night and cricket just doesn't seem to make sense because it's on the edge of the roof, but I need to somehow divert the water so that it goes around the chimney and not off the edge, right? The chimney is about 8 ft from the ridge.
What's the proper solution here? Note that the chimney is going to have vinyl siding on it. Do we use tall flashing on that top edge and let the water run right into it?
Any thoughts would be greatly appreciated, by me and my siding guy.
kindejj is offline   Reply With Quote
Old 02-24-2009, 01:35 PM   #2
BUILDER / REMODELING CONT
buletbob's Avatar
there is not going to be much water going to run down that area of the roof. What I would do is install a layer of ice and water under the existing roof shingles and up the side of the chim. then install alum or copper flashing 12 " up the roof and 12" up the chim. wall pitch it slightly back toward the main roof. you don't want it to drain off the edge. BOB
Old 02-24-2009, 01:40 PM   #3
Yeah, it's pretty close to the ridge, so there will not be too much water at any 1 time. Can you please explain this to me more...wall pitch it slightly back toward the main roof. you don't want it to drain off the edge. That is my real problem How do I get the water to go towards the roof vs. over the edge. Thanks
Old 02-24-2009, 02:11 PM   #4
buletbob's Avatar
when u install the flashing lift it at the rake side and lower at the back of the chim.
Chimney Confusion (Long) wehcyar Building & Construction 10 02-12-2017 06:16 AM
Where a wall meets a chimney joelbuckley Carpentry 12 11-13-2008 03:19 PM
Roof Leak Around Chimney robertr4836 Roofing/Siding 3 03-11-2008 11:23 AM
Looks like leaking around the chimney - roofer says it is the chimney itself Salvatorparadise Roofing/Siding 6 03-07-2008 03:12 PM
