Cricket ? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 09-05-2010, 01:04 PM   #1
Rewards Points: 14
Cricket ?
We have 28" wide by 6' chimney located at the gable side of the house (starting 4 ft below the ridge). Pitch is 6/12, shingles. Overhang is 2ft (about the size of the chimney) and there is a rafter (subfascia) with the fascia going alongside the chimney that has rotted (over many years).
My question is: Is it a good idea to have a little cricket in this scenario to divert the water ? And with cricket is there a concern that the diverted water then will run down the fascia (of course there a little pieces of shingles there). The flashing / counterflashing will be aluminum.
One option I was considering was a cricket with uneven sides (e.g. 20" and 8") so that not as much water would flow down the fascia. Is that done ?
It is Midwest, so lots of snow.
Thanks in advance.
datadriven is offline   Reply With Quote
Old 09-05-2010, 02:45 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
how old is the house?,i don't think a ''cricket'' is ever a bad idea...just it isn't always needed,typically you would use one with any chimney over 2' wide
Tom Struble is offline   Reply With Quote
Old 09-05-2010, 05:02 PM   #3
Rewards Points: 14
House is about 45 yrs. old. Any opinions on "uneven" sides cricket (so that most of the water would flow to the roof side, not gable side) ?
Old 09-05-2010, 05:11 PM   #4
Shut in w/o Home
seeyou's Avatar
Rewards Points: 502
What you're proposing is a good idea. The only down sides are the appearance from the gable side and the fact you're using aluminum. You're likely going to be creating some joints that you'll have to rely on caulk to seal using aluminum. I'd look into a material you can solder.
seeyou is offline   Reply With Quote
Old 09-05-2010, 09:07 PM   #5
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
No cricket. Just box-fold the gable side, flush with the edge shingles. Tinner's wing should be at least 2" from (past) the corner that will allow the water out.
tinner666 is offline   Reply With Quote
Old 09-06-2010, 06:25 AM   #6
Rewards Points: 14
Tinner, would what you suggest be possible to do with aluminum ?
Old 09-06-2010, 06:45 AM   #7
Pro Slate Roofer
tinner666's Avatar
Box fold is self explanatory.
And tinner's wing, along with cutting the last step to fit the pan.
Cricket ?-box-folding-flashing-8-.jpg   Cricket ?-chimney-job-12-.jpg   Cricket ?-chimney-job-7-.jpg
Old 09-06-2010, 07:16 AM   #8
Residential Roofer
Slyfox's Avatar
Yes, using aluminum is ok.
The method Tinner explained is much better than your cricket idea, IMO.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
Old 09-06-2010, 07:25 AM   #9
Pro Slate Roofer
tinner666's Avatar
Thanks Steve! I got involved with the details and forgot to say Aluminum was OK.
Old 09-06-2010, 07:28 AM   #10
Pro Slate Roofer
tinner666's Avatar
The box-fold MUST be turned UP the roof! Not sideways!
And the top of it must be sealed. I do it so one side or the other has more metal then the other, and fold the top over to close it. Some caulk or gutter sealed can be used at the fold to prevent water droplets from freezing inside the fold.
Old 09-06-2010, 08:34 PM   #11
Rewards Points: 14
If I did not mentioned this before, the total width available on the "rake" (outside) side of the chimney is about 5 inches: (1" gap to rafter + 1.5" rafter + 1" fascia (1x10 cedar) + 1"trim on top of fascia (1x3 cedar) + 0.5" shingle overhang). That should not make any difference here, correct ?
You don't think I need any special way of turning "half" of the water (4ft down the ridge worth times 2ft. wide) away from trying to get through 5" - 2" (for tinner's wings) = 3" left on top of shingles ?
I found this
http://copper-by-design.com/cc/cp/im/Fenley35.jpg
to deal with similar setup, but it seems complicated.
Thanks so much for your help.
Old 09-06-2010, 09:38 PM   #12
Pro Slate Roofer
tinner666's Avatar
You could get that complicated if you want. Not necessary though.
Standard tinner's wing runs about 6-8" past the corner, then modifed as shown to have the fold about 2" from the corner.
On the rake side, run the last step flashing about 1" above the brick corner, and cut as shown above to fit the back pan. Box fold it.
Hope this helps too. http://www.albertsroofing.com/Chimney%20Repair.htm
Don't over-think it. You're talking about 8 sq. ft. of area, at the ridge. Unless the local RFD is spraying water there, you're not going to have any volumn to speak of.
Whats the life span of a cricket?? 4just1don Pest Control 4 10-22-2014 02:03 AM
Contractor reccomendation : Install cricket... Alan Roofing/Siding 9 03-04-2010 08:18 AM
cricket? hms Roofing/Siding 3 10-17-2008 06:46 AM
Best way to keep cricket stay out of the house. Help please! DKNY General DIY Discussions 2 09-03-2006 02:47 AM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 10:59 PM
