Cricket? - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 10-16-2008, 10:46 PM   #1
hms
Remodeling contractor
cricket?
i have a dormer that comes down in a valley. i know, wonderful! I am told that I need to build a cricket along the side of the dormer. Not at the top edge but along the side. Wouldn't that cause the water to run even worse off the top of the cricket back down or up along the top of the dormer edeges? Maybe it's just me but that doesn't make sense to me. please explain.
hms is offline   Reply With Quote
Old 10-16-2008, 10:49 PM   #2
hms
PS I don't do roofing or roofing related carpentry
Old 10-17-2008, 05:43 AM   #3
BUILDER / REMODELING CONT
buletbob's Avatar
what a cricket's purpose is, is to create a new valley or path for the water to flow away from a problem are. it could be constructed in many different fashions. if you post a picture of your problem we will be better able to guide you with the right information. BOB
Old 10-17-2008, 05:46 AM   #4
Residential Roofer
Slyfox's Avatar
You install a cricket along side a wall, chimney, etc., to re-direct precipt from gathering, or running dierectly into the wall or side of the chimney, etc.
I surely can not tell you if a cricket will help with the problem your having with out a more detailed description and pics,
and altho crickets are not as commonly used as saddles,
they are frequently used and will work if installed properly.
God Family Country Work Play
Facebook <> Twitter
Slyfox Exteriors Co.
Slyfox is offline   Reply With Quote
water leaking through brick chimney quigleybmd Concrete, Stone & Masonry 45 02-26-2013 04:26 PM
Best way to keep cricket stay out of the house. Help please! DKNY General DIY Discussions 2 09-03-2006 01:47 AM
Cricket Construction on Metal Roofing? Lion Gordon Roofing/Siding 1 07-20-2005 09:59 PM
