Cracked Roof Decking - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 03-31-2012, 11:37 PM   #1
Cracked roof decking
We are selling our home and the buyer's inspector found a cracked board in the roof decking of our 1938 home. He said it should be blocked as needed form the under side. What does this mean and would could we expect in cost. Any help is much appreciated. Thanks - Need to sell.
Beancal is offline   Reply With Quote
Old 04-01-2012, 12:13 AM   #2
Rewards Points: 13,450
No pictures, not much info so it's anyones guess.
A house that old was built before plywood or OSB so they used 1 X 6's. It was common to have a weak area where a knot or flaw in the wood was to have it fail.
Pretty simple job to remove the shingles and tar paper in that area, cut out the bad board and replace, add new tar paper and install new shingles.
Keep in mind I can only guess since there's not enough info.
Old 04-01-2012, 02:56 AM   #3
Doing This Way Too Long
Rewards Points: 532
Or just block it from underneath and toenail into the rafters
OldNBroken is offline   Reply With Quote
The Following User Says Thank You to OldNBroken For This Useful Post:
Windows on Wash (04-01-2012)
Old 04-01-2012, 06:09 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 3,086
This would be the easier and less disturbance way to fix the board.
Old 04-02-2012, 10:53 PM   #5
Metal Roofing
Rewards Points: 600
If its is just a broken 1x6 i would block it from the attic as mentioned. Price is hard to say because we lack some details, i would ball park it at $150-$250. $150 if your on the street i am working on or near , But most likely i would expect someone to charge $200 maybe $250.
AndyWRS is offline   Reply With Quote
mobile home peaked roof has cracked in a couple brenda o Drywall & Plaster 5 02-06-2011 06:06 PM
Replace the roof or not??? Leaked only once when it snowed chasqui Roofing/Siding 10 04-13-2010 10:02 PM
Please help with the design of this roof jaymay75 Building & Construction 1 05-06-2008 09:44 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
what roof decking material should i use? chrisd11 Carpentry 9 06-18-2006 09:32 PM
