Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 03-24-2005, 02:16 PM   #1
Cost of replacing a rafter in our roof???
We've got a cracked rafter in our roof and need to replace it, the roof is slightly concave at this position and I'm told we'll need to jack the roof slightly and then install another rafter next the the cracked one to provide support... wondering how much something like this might cost. the shingles and rest of the roof are 3 years old (80 year old house)... any info would be great. thanks.
bikerboy337 is offline   Reply With Quote
Old 03-24-2005, 07:34 PM   #2
Contractor
This is called 'sistering'. Much depends on the location of the fracture, the length and the ability to get the 'sister' into place.
For a 'cakewalk' job, I would charge about $500.00. You can go up from there. A long fracture may require getting a 10-12 ft piece of lumber into the attic, sometimes this means putting large holes in a ceiling. Often it can go in through a soffit. Short breaks, like from a knot or impact are much easier.
Teetorbilt is offline   Reply With Quote
Old 04-01-2005, 09:17 PM   #3
Grumpy's Avatar
Send a message via AIM to Grumpy Send a message via MSN to Grumpy Send a message via Yahoo to Grumpy
If installing the roof and we run across a rafter that needs to be sistered, it's $5.5 per linear ft. We brace up the existing rafter if sagging then sister the new rafter. We would go at least 3' pas tthe sag in each direction, for a minimum of 6'.
If sistering the rafter and not installing the roof, this can be a very messy job depending on access to the attic.
-Grumpy
Chicago Roofing Chicago Gutters
Sometimes the savings that comes from doing it yourself can be blown away with one mistake.
The information found in this post is not to be considered legal advice. All information should be considered relative, not specific. Never attempt any repairs you are not comfortable with. Always maintain saftey! The author of this post takes no responsibility for any losses that occur. Use at your own risk.
Grumpy is offline   Reply With Quote
Old 04-24-2005, 07:19 AM   #4
747
registered
747's Avatar
I think the contractor on that house might just open pandora's box Meaning oh man lookout there is more than meets the eye on this job.
747 is offline   Reply With Quote
More On This Topic
Roof leaks may not be immediately apparent, which is one of their inherent problems. As a roof leaks, there is the danger that mold and mildew will accumulate. In addition, actual structural damage is also a possibility. That's why it is so important to... Read More »
The outside roof pitch on your home can be made more attractive by increasing the pitch of the roof. Increasing the roof pitch also provides a more efficient way for rain and snow to drain more easily off of the roof. Read on to learn more. Read More »
When it comes to a tornado it doesn't matter what the intensity of it is if your house is not properly built to withstand it. If your house is not wind-proofed it can suffer a lot of damage. Follow these steps to prepare for a tornado and prevent... Read More »
Whether you need a garage for your vehicle or extra storage it will be a wise investment for your home. The plans for a garage can be purchased off the Internet instead of using a high priced architect because of the simplicity of the design. If you want... Read More »
On behalf of expert village my name is Husain Abdul Alim I’m here to tell you about carving figurines. To price this one I’ve had this up in the gallery Gerome, this is been priced the first time I had it up there was $1600.00. The last show... Read More »
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing 4 11-19-2006 07:17 AM
Replacing a laundry room roof. Tomcat1066 Building & Construction 5 11-11-2006 04:08 PM
Replacing Roof Boards joedadog Roofing 12 05-14-2006 11:10 AM
Cost for new roof in Florida? FlutterGirl Roofing 3 09-18-2005 09:06 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
