Cost Estimate For 5 Sheets Of Siding And Boards:1400$ - Roofing/Siding - DIY Home Improvement | DIYChatroom
Old 11-13-2013, 11:39 AM   #1
Rewards Points: 81
Cost Estimate for 5 sheets of siding and boards:1400$
Hey guys!
I received an estimate of $1,400.00 to replace five sheets of siding; replace twenty-five feet of 1x2 boards; caulk, scrape and paint exterior. This includes labor and materials. Does this sound like a fair quote?
The property management company does not want to obtain another estimate (this is a good PM, and they advised me they found this vendor reasonable and with good results of his work).
The property is a 1150 sq ft single family house in Fort Worth, TX
Thanks!
Edita
edavt04 is offline   Reply With Quote
Old 11-13-2013, 11:52 AM   #2
GBrackins's Avatar
Rewards Points: 2,108
first in regards to pricing estimates "How much will it cost?" Asking for price estimates here.
I'd recommend contacting local contractors to obtain estimates, then you'll know if your quote sounds fair or not.
good luck!
Gary
"You get what you pay for, and sometimes free costs more!"
GBrackins is offline   Reply With Quote
Old 11-13-2013, 12:18 PM   #3
Rewards Points: 1,016
Get multiple quotes - compare - select.
Be sure and check reference of similar projects done recently.
____________
Vince
Old 11-13-2013, 12:22 PM   #4
GBrackins's Avatar
make sure you are receiving an apples to apples quote. sometimes one quote is less because it does not cover the same items as another quote
and Vince hit the nail right on the head, get references from the contractors and call them to discuss their projects and if they would hire that contractor again.
Gary
Old 11-13-2013, 05:13 PM   #5
Rewards Points: 13,260
We have no picture, never been to the property, never seen the whole quote, no idea what your local labor, or materials cost are.
Do not even know where on the planet you are because you did not add your location to your profile.
Old 11-13-2013, 05:33 PM   #6
kwikfishron's Avatar
Rewards Points: 176
Joe, did you even read the post?
As others have mentioned get more quotes.
kwikfishron is offline   Reply With Quote
Old 11-13-2013, 05:53 PM   #7
Gymschu's Avatar
Rewards Points: 462
Wow, that's a good deal.
Old 11-13-2013, 06:25 PM   #8
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 42
Prices can vary widely in different parts of the country. Without seeing the job and not knowing labor rates in Texas, it would be hard to guess.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-13-2013, 06:31 PM   #9
I missed the part about the location added in the wrong place but the rest of my reply still applies.
Old 11-13-2013, 06:40 PM   #10
Rewards Points: 582
you might loose that fight ..if .. the property management has the control to hire who it wants.... but any way you local suggest alittle higher price bracket as i recall ....cost are more based on earnings being higher...ben sr
Old 11-13-2013, 06:43 PM   #11
MEASURE ONCE, CUT TWICE
123pugsy's Avatar
Rewards Points: 722
If you have an idea what the material cost, add about 20-30% mark up to that for the contractor.
Deduct that amount from the quote amount and divide it by 60 for 60 bucks an hour.
This will show you how many hours the contractor should be finishing the job in. Some guys are around 50 an hour depending on location all the way to maybe 70-80 an hour.
When you get this figure, consider if it's a reasonable amount of time to do the project. You should have a pretty good idea since it's your home and you know the project. You'll then see if by using this rough guide that the result is like only 8 hours, and it looks like a 12 -14 hour project, you're getting a deal. If however, you can clearly see the project should take a few days, it might not be wise to go with the cheapest quote. When a quote is way under, short cuts usually start to happen.
If you've got a good referral and you know that indeed the contractor does good work, I'd say you may very well be doing good for 1400 bucks.
Pugsy.....my project: Total House Rebuild Bungalow to Two Story
123pugsy is offline   Reply With Quote
Old 11-15-2013, 10:46 AM   #12
Rewards Points: 212
Always get multiple quotes -apples to apples as was stated above - then make your decision.
orange is offline   Reply With Quote
