Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Roofing
Old 09-20-2006, 08:33 AM   #1
Corrugated plastic fixtures
Hi, I've just built the frame for a lean-to and cut the plastic corrugated sheets to size. My question relates to fitting these sheets to my timber frame.
Is there any specific fixture I need to use ?
I've noted I need to enter at the peaks of the plastic but just wondered on the fixtures.
Any help appreciated
tonydee is offline   Reply With Quote
Old 09-20-2006, 05:31 PM   #2
World famous jerk.
You need to use the hex washer head screws with the pre-installed rubber washers under the heads. I think you might be in the UK or AUS, but in the US we call these "metal roof screws" or "barn tin screws".
mdshunk is offline   Reply With Quote
Old 09-20-2006, 08:00 PM   #3
Commercial Roofing
AaronB's Avatar
Yep, neoprene washered screws is the way to go.
Free inspection within 12 miles
Seamless Polyurea Roofing Membranes for Metal Roofing, Roof Leak Repair, Seamless Commercial Spray Foam Insulation, Seamless Commercial Roofing, SPF Roofing, Industrial Insulation, Our trucks are red but our roofing is GREEN!
AaronB is offline   Reply With Quote
Old 09-21-2006, 01:56 AM   #4
I blame ProWallGuy
Tony, there is a type of lathing sold in the USA that will match the undulations of the sheeting. You can use that to install, although it is a very rough and inexpensive wood with zero aesthetic appeal.
Otherwise you can fasten it with the screws mentioned, but don't drive the screws down tightly. Just snug them up to compress the washer a bit.
Take a look here for an example.
Double A is offline   Reply With Quote
Old 07-16-2008, 11:36 PM   #5
To add the responses you've received, I purchased 2'x1" sections of wood that are cut to match the corregation of my plastic. They are then nailed/screwed to the frame, and the plastic is screwed to these boards.
Now, I have a question for you. I was wondering how you cut and what you used to cut your corregated plastic. I've got 12' sheets I need to cut down to 5'.
Thanks for any help you can give. v
vmediate is offline   Reply With Quote
Blue plastic receptical/switch boxes used as junction boxes? alexz Electrical 7 04-09-2013 09:40 PM
Corrugated over Corrugated picman98 Roofing 1 07-01-2007 01:36 PM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 02:46 PM
Where to find 2½" square plastic drain pipes The_Flash Roofing 4 07-25-2005 08:35 AM
